Is this possible? Can an object move through an animation while its gizmo stays stationary, so the map assigned to it looks as if its moving across it? Am I describing this accurately? Is it possible to "disconnect" the gizmo from the object, so the map stays anchored as the object moves around?
you want the material to stay in 1 place?
:huh:
if this is the case apply a uvw map and play with the rollout it has.
I think you're going to have to create an animated texture. Search Youtube. There are lots of videos on this subject.
