Lee Mac, or someone else, can you help me to change this function to select all entities with linetipe are not continuous? And as in this case, I also have some entities with linetipe bylayer, and others with individual linetype.
Here is a quick modification:
(defun _selectlinetype ( lt / df ls )
   (while (setq df (tblnext "LAYER" (null df)))
       (if (eq lt (cdr (assoc 6 df)))
           (setq ls (cons "," (cons (cdr (assoc 2 df)) ls)))
   (sssetfirst nil
       (ssget "_X"
           (cons
               (cons 410 (if (= 1 (getvar 'CVPORT)) (getvar 'CTAB) "Model"))
               (if ls
                   (list
                       (cons -4 "<OR")
                       (cons 6 lt)
                       (cons 8 (apply 'strcat (cdr ls)))
                       (cons -4 "OR>")
                   (list (cons 6 lt))
To be called with the name of the linetype, e.g:
(_SelectLinetype "HIDDEN")
I shall leave the task of adding a user prompt (if necessary) to you.
A reference for the DXF group codes can be found here.
  • Replies 65
  • luiscarneirorm
    33
  • BlackBox
    12
  • Lee Mac
    11
  • Tharwat
    5
Posted Images
P.S.: RenderMan, thanks for your post, but I think I'll leave that for later (it's hard for me, for now:cry:)
You're welcome, luiscarneirorm. :)
I'm sorry that my post was not able to help you more.
   (sssetfirst nil
       (ssget "_X"
           (cons
               (if ls
                   (list
                       (cons -4 "<OR")
                       (cons 6 lt)
                       (cons -4 "OR>")
                   (list (cons 6 lt))
I want to select all entities with linetype not continuous.
I tried to change this way:
(if ([b]not[/b] eq lt (cdr (assoc 6 df)))
but as I feared is not so simple
Perhaps, replacing:
(cons 6 lt)
... With this:
(cons 6 (strcat "~" lt))
:unsure:
Close, but there are a few extra parts to add:
(defun _selectifnotlinetype ( lt / df ls )
   [color=red](setq lt (strcase lt))[/color] [color=green];; To remove case-sensitivity[/color]
       (if [color=red](not[/color] (eq lt [color=red](strcase[/color] (cdr (assoc 6 df))[color=red])[/color])[color=red])[/color]
   (sssetfirst nil
       (ssget "_X"
           (cons
               (if ls
                   (list
                       (cons -4 "<OR")
                       (cons 6 [color=red](strcat "~" [color=black]lt[/color])[/color])
                       (cons -4 "OR>")
                   (list (cons 6 [color=red](strcat "~"[/color] lt[color=red])[/color]))
(_selectifnotlinetype "Continuous")
Perhaps, replacing:
(cons 6 lt)
... With this:
:unsure:
this way also selects the entities that are "bylayer (continuous)" :(
And i have exactly the same problem with your code Lee Mac
Lee, i change your code to:
   (setq lt (strcase lt)) ;; To remove case-sensitivity
       (if (not (eq lt (strcase (cdr (assoc 6 df)))))
   (sssetfirst nil
       (ssget "_X"
           (cons
               (if ls
                   (list
                       (cons -4 "<OR")
                       (cons 6 (strcat  lt))
                       (cons -4 "OR>")
                   (list (cons 6 (strcat  lt)))
and the result is already closer to what I meant, but still selects some entities are on layer with linetype dashed, but have the individual linetype defined as Continuous.
I did just the opposite of what RenderMan tell me before: i replace
with
(cons 6 lt)
:unsure:
P.S: I just now detected, but the function of post 22, happens the same thing, if the entities have a lineweight set individually, and not by layer, it is not selected:(:(
Good catch, I had overlooked that :oops:
Try this instead:
   (sssetfirst nil
       (ssget "_X"
           (cons
               (if ls
                   (list
                       (cons -4 "<OR")
                           (cons -4 "<AND")
                               (cons 6 "ByLayer")
                           (cons -4 "AND>")
                           (cons -4 "<NOT")
                               (cons 6 (strcat lt ",ByLayer"))
                           (cons -4 "NOT>")
                       (cons -4 "OR>")
                   (list
                       (cons -4 "<NOT")
                       (cons -4 "NOT>")
To correct post#22:
(defun c:test ( / df ls lw )
   (while
       (and (setq lw (getreal "\nSpecify LWeight: "))
           (or
               (< lw  0.0)
               (< 2.11 lw)
       (princ "\nLineweight must be 0.0 <= x <= 2.11")
   (if lw
           (setq lw (fix (* 100 lw)))
               (if (= lw (cdr (assoc 370 (entget (tblobjname "LAYER" (cdr (assoc 2 df)))))))
           (sssetfirst nil
               (ssget "_X"
                   (cons
                       (if ls
                           (list
                               (cons -4 "<OR")
                                   (cons -4 "<AND")
                                       (cons 370 -1)
                                   (cons -4 "AND>")
                                   (cons 370 lw)
                               (cons -4 "OR>")
                           (list (cons 370 lw))
These ssget filter lists can be tricky at times...
She's work perfectly :D
Based on this I'll try to correct the other function
Thank you very much :beer:
Hi.
i try to insert this code in the end off this function, to put the selected entities in the current layer.
(defun c:espessura ( / df ls lw [color=red]e[/color] )
   (while
           (or
               (< lw  0.0)
               (< 2.11 lw)
   (if lw
               (if (<= lw (cdr (assoc 370 (entget (tblobjname "LAYER" (cdr (assoc 2 df)))))))
           (sssetfirst nil
               (ssget "_X"
                   (cons
                       (if ls
                           (list
                               (cons -4 "<OR")
                                   (cons -4 "<AND")
                                       (cons 370 -1)
                                   (cons -4 "AND>")
                                   (cons 370 lw)
                               (cons -4 "OR>")
   [color=red](setq e (getvar "clayer"))
        (command "change" ls "" "prop" "layer" e "")[/color]
but as I feared I did not succeed:( (the code in red is what I added)
Command: espessura
Specify LWeight: 0.4
change
Select objects:
Command: ESPESSURA Unknown command "ESPESSURA".  Press F1 for help.
Command: prop Unknown command "PROP".  Press F1 for help.
Command: layer
Current layer:  "0"
Enter an option
[?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/MATerial/Plot/Freeze/Thaw/LOck
/Unlock/stAte/Description/rEconcile]: 0
Invalid option keyword.
; error: Function cancelled
what am I doing wrong? :unsure:
P.S: Lee, this is your function, I just changed it's name
Edited by luiscarneirorm
The variable 'ls' stores a list of strings, not a selection set as required by the 'chprop' command.
I use the sssetfirst function to highlight the selection set returned by ssget, but if instead you wanted to use this selection set in the code, it would be easier to bound it to a variable, e.g.:
(defun c:espessura ( / df en i ls lw ss )
   (while
           (or
               (< lw  0.0)
               (< 2.11 lw)
   (if
       (and lw
               (setq ss
                   (ssget "_X"
                       (cons
                           (if ls
                               (list
                                   (cons -4 "<OR")
                                       (cons -4 "<AND")
                                           (cons 370 -1)
                                       (cons -4 "AND>")
                                       (cons 370 lw)
                                   (cons -4 "OR>")
           (setq en (entget (ssname ss (setq i (1- i)))))
           (entmod (subst (cons 8 (getvar 'CLAYER)) (assoc 8 en) en))
In this way, I iterate through the Selection Set bound to the variable 'ss' using the repeat loop and modify the layer of each entity in the set.
Not a problem :)
Sorry, I try but can not solve by yourself.
The functions works, but as I said before, if the entity is in a layer with lineweight less than 'lw' and this entity have your lineweight set individually greater than 'lw' it should be selected, but that does not happens:(
But if on the contrary, if the entity is in a layer with lineweight greater than 'lw' and this entity have your lineweight set individually less than 'lw' it is not selected, the funccion works correctly in this case.
Sorry if my explanation is too confusing :oops:
So you want to alter all entities with Lineweight less than the specified lineweight? I didn't notice your modification to this effect :oops:
Try this modification:
   (while
           (or
               (< lw  0.0)
               (< 2.11 lw)
   (if
       (and lw
               (setq ss
                   (ssget "_X"
                       (cons
                           (if ls
                               (list
                                   (cons -4 "<OR")
                                       (cons -4 "<AND")
                                           (cons 370 -1)
                                       (cons -4 "AND>")
                                       (cons -4 "<=")
                                       (cons 370 lw)
                                   (cons -4 "OR>")
                               (list
                                   (cons -4 "<=")
                                   (cons 370 lw)
   (while
           (or
               (< lw  0.0)
               (< 2.11 lw)
   (if
       (and lw
               (setq ss
                   (ssget "_X"
                       (cons
                           (if ls
                               (list
                                   (cons -4 "<OR")
                                       (cons -4 "<AND")
                                           (cons 370 -1)
                                       (cons -4 "AND>")
                                       (cons -4 "[color=black]<[/color]=")
                                       (cons 370 lw)
                                   (cons -4 "OR>")
                               (list
                                   (cons 370 lw)
I finally able to solve a problem alone :celebrate:
Lee Mac
less
i want to alter all entities with Lineweight greater than the specified lineweight.
I just had to reverse 2
   (while
           (or
               (< lw  0.0)
               (< 2.11 lw)
   (if
       (and lw
               (setq ss
                   (ssget "_X"
                       (cons
                           (if ls
                               (list
                                   (cons -4 "<OR")
                                       (cons -4 "<AND")
                                           (cons 370 -1)
                                       (cons -4 "AND>")
                                       (cons -4 "[color=red][b]>[/b][/color]=")
                                       (cons 370 lw)
                                   (cons -4 "OR>")
                               (list
                                   (cons 370 lw)
Glad that you could solve it yourself :thumbsup: I hope your learning of LISP has benefitted along the way :)
Hello again...
I am able to implement some functions for my work, without help :shock:, but now there is a problem that I can not solve:x
I have a function to recreat the hatch boundaries.
defun C:F8 (/ sset item i)
(setq sset
   ssget "_X" '((0 . "HATCH"))) i -1
repeat (sslength sset)
 setq item (ssname sset (setq i (1+ i)))
 (command "._hatchedit" item "_B" "_P" "_Y")
If I run only the function it works correctly, but I want to run it, after another function that I explode the blocks that also contain some hatch's
(defun C:f7 (/ AllBlocks SolOnly )
(setvar "qaflags" 1)
(setq AllBlocks (ssget "X" (list (cons 0 "INSERT"))))
(while (/= AllBlocks nil)
  (command "_.explode"  AllBlocks "")
 );progn
);while
(setvar "qaflags" 0)
the problem is:
Command: f10
_.explode
Select objects:   1 found
Select objects:
Command: _.explode
Select objects:
Command: ._hatchedit
Select hatch object:
Use the Hatch Edit dialog box to modify gradients.
Select hatch object: _B
Specify first corner: _P
Invalid window specification.
the F10 function just call the F7 function and then the F8 function
my goal is to change the hatch boundaries to a specified layer, and if it is possible, after this, delete the hatch's and the older original boundaries :?
I've been searching and have tried to solve this problem in several ways, but I can not do it.
I am suspicious that the problem stems from the F7 function, to change the variable value "qaflags"
I am right? how can I solve this problem?
Edit:
I discovered that this was not my problem
The problem is that after i explode the block, i get hatch's with invalid boundaries...
I came up with a new problem :oops:
the upper triangle is defined as a polyline with
start segment with: 0
end segment with : 1.5
if i explode them, it becomes a simple line, but I need the outline is as below
it is possible to do that???
poli.dxf
Hi.
Lee,i went through your site and found there just what I needed (Polyline Outline), but does not work properly, at least in my case:(
You (or someone else) can take a look?
I put the file in the previous post
P.S: I've been testing with several polylines, and found that it works properly only with the start segment with, but the end segment with appears to me that ignores.
