IJ31 Posted October 8, 2008 Posted October 8, 2008 I have set up 3 text styles and have put several notes in model space. When I go to my layout page none of the text is displayed. Does anyone know what to do, cheers. PS Architectural Desktop 2009 Quote
feargt Posted October 8, 2008 Posted October 8, 2008 check that your layer for your viewports is turned on and that the vport is big enough that you can also see the location of the text. also try clicking in the viewport and doing a regen. Quote
IJ31 Posted October 8, 2008 Author Posted October 8, 2008 Cheers but still does not seem to work. I have set up 3 new text styles and it is these that are not appearing as some other text is still there. Any other thoughts. Quote
Attila The Gel Posted October 8, 2008 Posted October 8, 2008 possible errors; Layers freezed or thauwed Text style may give a problem try another font, Text color is white (255,255,255) and background to Quote
IJ31 Posted October 8, 2008 Author Posted October 8, 2008 It still does not appear. If I write new text but don't use any of the 3 new styles it can be seen in the layout page so it must be something to do with the settings in the text styles. these text styles are annotative. Quote
Attila The Gel Posted October 8, 2008 Posted October 8, 2008 Try a new layout to see the if problem isn't your layout settings and layout layer settings. also press Ctrl+A when your in your viewport and see if the invisible text grabpoints can be seen? Quote
feargt Posted October 8, 2008 Posted October 8, 2008 then check the scales that are visible in the viewport for the annotative text. If the correct scale is not visible then you will not see it displayed Quote
manhattan Posted November 6, 2008 Posted November 6, 2008 i had a similar problem when using object viewports instead of standard viewports, just a thought Quote
chelsea1307 Posted November 7, 2008 Posted November 7, 2008 make them so they are not annotative. I dont know why but that seems to fix the dissapearing text problems ive had Quote
BOB'27T Posted November 10, 2008 Posted November 10, 2008 A quick fix if the text is not visible: Next to the annotation scale, click the light bulb on. Blue when off, yellow when on. Quote
jesterminute Posted January 6, 2018 Posted January 6, 2018 Make sure youre not on Annotative in Model Space . Double click your text in model space, and at the top left check that Annotative is not highlighted in blue. After that, it should appear in layout. Quote
Ski_Me Posted January 8, 2018 Posted January 8, 2018 After almost ten years I think the OP might not be to concerned with this problem anymore. Quote
CyberAngel Posted January 8, 2018 Posted January 8, 2018 After almost ten years I think the OP might not be to concerned with this problem anymore. True, but someone else may have the same issue. Every piece of info is valuable. Quote
JoeS09 Posted February 14, 2021 Posted February 14, 2021 I have this problem in 2021, and appreciate the solution Quote
VRP Posted August 21, 2024 Posted August 21, 2024 (edited) I resolved it by creating new viewport in the same layout. Edited August 21, 2024 by VRP Quote
