For some reason my angles are all way off. I type line 3
Have you checked the direction of your zero angle in units properties? It looks as though it could be north instead of east.
If you want to go the System Variable way, then check ANGBASE. It should be 0, but looks to be 90 or 270 in your picture.
Edited by eldon
Look to see if you are using relative or absolute angle values.
