Hello,
I have a generic title block that I made in a template. When I start a new drawing its there and i can click it and edit some of the fields, alls good. However, I have a few drawings that I want to have the same fields in so I try to copy and paste the title block in the one drawing into the other but when I do this is pastes the title block from the template and not the one that I edited in the other drawings and copy/pasted. Weird!!! Any help is much appreciated.
Tnx
no that didnt do anything. frankly, i have no idea what the purpose of purge is, i read some stuff on it and it doesnt really apply. still same problem. i feel im better off sometimes just staying away from blocks and just copying stuff manually from other dwgs
Did you delete the title block and then purge?
Sounds like the attributes are PRESET to the default value upon insertion. Use BATTMAN to deselect that option in all the attributes you wish to bring into the drawing.
