Hi All,
I have a problem when try to import shape files in to Autocad as batch.
I tried to loop files one by one and import using Mapimport.
I am not getting how select Attribute data information to different shape file in run time. If i use .ipf file it is fixed to that particular table only.
Please let me know, is there a way to import shape files as batch process?
Thanks,
Kumar.
Hi All,
After some investigation i found data options in "mapimport4" command.
But when i try to use this command through lisp it is giving following error.
Command: (command "mapimport4")
mapimport4 Enter file format DGN/MIF/SHP/TIC  <SHP>: nil
Enter file format DGN/MIF/SHP/TIC  <SHP>: shp
Import file name <D:\aawork\BusBar.shp>:
Load saved settings? (Yes/No) <N>: N
Preprocessing...error encountered.
Please help me how to solve this problem.
Thanks,
Kumar.
Hi all,
Finally i got solution for this.
(command "-mapimport" "SHAPE" shpfile "n" "L" "S" layname "D" "C" "P" "P")
Thanks,
Kumar.
