KariCad Posted July 11, 2011 Share Posted July 11, 2011 I am drawing a plan view of building that is 11 feet by 36 feet. I thought my map units were in feet but when I draw in the linear dimensions, it reads 11 inches x 3 feet. How do I change this? Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted July 11, 2011 Share Posted July 11, 2011 Check the Primary Units tab in your dimension style. Make sure the scale is set to 1. Welcome to the forum! Quote Link to comment Share on other sites More sharing options...
KariCad Posted July 11, 2011 Author Share Posted July 11, 2011 Thanks for the reply! I checked the Dimension style-Primary Units and the scale is 1. I tried changing the unit format as well and its still reading 11"x36". Any other ideas? Quote Link to comment Share on other sites More sharing options...
tzframpton Posted July 11, 2011 Share Posted July 11, 2011 type UNITS and make sure your Drawing Setup is correct. Are you properly typing in the coordinates when you are drawing? Quote Link to comment Share on other sites More sharing options...
KariCad Posted July 11, 2011 Author Share Posted July 11, 2011 In the Drawing Units window, the Insertion scale is set at Feet. When I measure the line by selecting it using the Line and Arc Information button, it gives the distance in feet. But when I use the Linear button and measure the same distance, it gives it in inches. I am confused. Did I mention that I am teaching myself how to use this program? This program is too much. Quote Link to comment Share on other sites More sharing options...
tzframpton Posted July 11, 2011 Share Posted July 11, 2011 When you type your coordinates, if you type 36 it will only be 36 inches. You have to type 36' for it to be 36 feet. Is this how you are inputting the distances? Just in case: http://docs.autodesk.com/ACD/2011/ENU/filesAUG/WS1a9193826455f5ffa23ce210c4a30acaf-7225.htm This is documentation that describes how to input distances. Quote Link to comment Share on other sites More sharing options...
KariCad Posted July 11, 2011 Author Share Posted July 11, 2011 I think I understand what you mean. This is what I tried: 1. Click on polyline button and click a point on drawing. 2. I then type "L" into the command line to specify length of line. 3. I type in 36' and I get an error that reads "Requires numeric distance or second point." If I type in just 36, it draws the line. That is how I originally drew it. Thanks for your help! Quote Link to comment Share on other sites More sharing options...
rkent Posted July 11, 2011 Share Posted July 11, 2011 In the Drawing Units window, the Insertion scale is set at Feet. When I measure the line by selecting it using the Line and Arc Information button, it gives the distance in feet. But when I use the Linear button and measure the same distance, it gives it in inches. I am confused. Did I mention that I am teaching myself how to use this program? This program is too much. Forget the insertion scale, go into UNITS and at the top left use the pull down and select Architectural. Now when you type in 36' it will give you that. Make sure you have Polar or Ortho on so when you pull your cursor away from a start point the line stays ortho. When you start Pline command you don't have to type L, just pick a point and continue. Quote Link to comment Share on other sites More sharing options...
KariCad Posted July 11, 2011 Author Share Posted July 11, 2011 That seems to work! Thanks everyone! Quote Link to comment Share on other sites More sharing options...
