zflowrpowr Posted July 9, 2011 Posted July 9, 2011 After 2 days of trying to crack this I can use some help please! I've just upgraded to 2011 (which may or may not be the culprit) I use a CTB to Plot my 2D Plan-sets and I'm having problems getting several arcs in the drawing to plotas hidden lines. Lines and P-Lines on the same layer print just fine, it's only the arcs that I can't get to stop plotting as solid lines. I'll detail my settings and include screen shots below, any help at all will be greatly appreciated, Thanks for looking! Settings Visual Style- 2D Wireframe Shade Pplot- "as displayed" PSLT Scale- 1 Celt Scale- 1 MSLT Scale-1 LT Scale .5, .25, .1 even 1.0 none make a difference Tile Mode- 0 Screen in Model Space Screen in Viewport- I'm referring to the RED Hidden Lines PDF Preview of File- Hidden Lines are Great! Final PDF- The Lines stayed as hidden perfectly, but the arcs reverted to solid The exact same thing happens with a another set of of arcs elsewhere in the drawing. Quote
SLW210 Posted July 11, 2011 Posted July 11, 2011 How does it look if sent directly from AutoCAD to a plotter/printer? Quote
