CyberAngel Posted July 6, 2011 Posted July 6, 2011 This is probably another one of those "quirks." I report it in the hope that, late in the 22nd century or so, someone will get around to fixing it. When I use Quick Select to find the objects on a particular layer, they are normally highlighted, and I can see the grips. Every so often that doesn't happen. I can still see the properties of the selection set, so the command has worked. If I select one of those objects, the rest are magically highlighted. Sometimes I select objects by layer simply to find out how many are there and where they are, so this particular quirk is frustrating. What makes it happen? If I knew, it would be a bug, not a quirk. At a guess, it happens after I've done several Quick Selects in a row. Quote
Jack_O'neill Posted July 6, 2011 Posted July 6, 2011 Maybe it gets tired, and thinks "man, I wish this guy would make up his mind":lol: Quote
CyberAngel Posted July 6, 2011 Author Posted July 6, 2011 Jack_O said: Maybe it gets tired' date=' and thinks "man, I wish this guy would make up his mind":lol:[/quote'] or the highlighter used by the little guy inside the box runs out of ink, and he has to go get another one ... Quote
