Hi,
I need a function to offset any object for a distance X without indicating the point.
The function must self find the point.
For example:
(defun c:set_offset (entObj set_dist side) ... )
where:
entObj - (car(entsel))
set_dist - eg. 150.0
side - 0 or 1 where 0 - inside, 1 - outside
Now I draw to offset line for any object:
I have two points from LWPOLYLINE, and function "polar" +/- 90 degree, distance 0.1
For CIRCLE and ARC I have center point +/- radius, distance 0.1
etc.
and then check the length of the line.
If I want inside - the shortest
If I want outside - the longest
Do you have any idea how to write the function, and simple way how to find a two points for any object?
Or maybe other way... to offset the objects?
best regards,
Z
Thank you Lee - it's working also in other CAD not for only AutoCAD - super ;)
(vla-offset (vlax-ename->vla-object (car(entsel)))) 150.0)
or
(vla-offset (vlax-ename->vla-object (car(entsel)))) -150.0)
can you tell me where can I find help for functions that are not in the AutoCAD help?
Good stuff :)
As an aside, if you are looking to manipulate the resultant offset objects, it may be easier to use:
(vlax-invoke <VLA-Object> 'Offset <Offset Distance>)
Since this will return a list of VLA-Objects and you needn't convert the Safearray Variant of objects returned by vla-offset or vlax-invoke-method.
My function:
(defun zk:Offset (entObj dist par_wz / vlaObj1 vlaObj2 dlg_1 dlg_2)
(cond ((equal (vla-Get-ObjectName (vlax-ename->vla-object entObj)) "AcDbPolyline")
(setq vlaObj1 (vlax-invoke (vlax-ename->vla-object entObj) 'Offset dist))
(setq dlg_1   (vla-Get-Length (vlax-ename->vla-object (entlast))))
(setq vlaObj2 (vlax-invoke (vlax-ename->vla-object entObj) 'Offset (* -1 dist)))
(setq dlg_2   (vla-Get-Length (vlax-ename->vla-object (entlast))))
     ((equal (vla-Get-ObjectName (vlax-ename->vla-object entObj)) "AcDbCircle")
(setq dlg_1   (vla-Get-Circumference (vlax-ename->vla-object (entlast))))
(setq dlg_2   (vla-Get-Circumference (vlax-ename->vla-object (entlast))))
);cond
(if (= par_wz 1)
(progn (if (< dlg_1 dlg_2) (vlax-erased-p (car vlaObj1)) (vlax-erased-p (car vlaObj2))))
(progn (if (> dlg_1 dlg_2) (vlax-erased-p (car vlaObj2)) (vlax-erased-p (car vlaObj1))))
);if
(princ (list vlaObj1 vlaObj2))
;TEST:
(zk:Offset (car(entsel)) 50.0 1)
Tell me please, why not remove objects: vlaObj1 or vlaObj2?
A very quick modification to your code to get it working for you:
(defun zk:Offset ( obj dist par_wz / vlaObj1 vlaObj2 dlg_1 dlg_2 )
 (if
   (cond
     ( (equal (vla-get-objectname obj) "AcDbPolyline")
       (setq vlaObj1 (car (vlax-invoke obj 'Offset dist))
             vlaObj2 (car (vlax-invoke obj 'Offset (- dist)))
             dlg_1   (vla-get-length vlaObj1)
             dlg_2   (vla-get-length vlaObj2)
     ( (equal (vla-get-objectname obj) "AcDbCircle")
             dlg_1   (vla-get-circumference vlaObj1)
             dlg_2   (vla-get-circumference vlaObj2)
   (if (= par_wz 1)
     (if (< dlg_1 dlg_2)
       (vla-delete vlaObj1)
       (vla-delete vlaObj2)
     (if (> dlg_1 dlg_2)
(defun c:test ( / e )
 (if (setq e (car (entsel)))
   (zk:Offset (vlax-ename->vla-object e) 50.0 1)
Note that vlax-erased-p tests whether an object is erased, and does not erase the object.
  • Thanks 1
Thank you Lee ;)
also for the explanation ;)
Hi,
my function looks like this:
;;----------------------------=={ zk:Offset }==------------------------------------;;
;;  entObj  - (vlax-ename->vla-object entity_name)                                 ;;
;;  dist    - distance offset                                                      ;;
;;  par_wz  - paramter ins/out, value = 1 or 2                                     ;;
;;  insPt   - point or nil                                                         ;;
;;  TEST:   (zk:Offset (vlax-ename->vla-object (car(entsel))) 20.0 1 (getpoint))   ;;
(defun zk:Offset (entObj dist par_wz insPt / oldSNAP vlaObj1 vlaObj2 dlg_1 dlg_2 objOffset)
(setq Err_NamePrc "zk:Offset")
(setq oldSNAP (getvar "OSMODE"))
(if entObj
		(setvar "OSMODE" 0)
		(if (not insPt)
				(cond ((equal (vla-Get-ObjectName entObj) "AcDbPolyline")		; or (vlax-get-property a 'ObjectName)
						(setq vlaObj1 (car(vlax-invoke entObj 'Offset dist))
						      vlaObj2 (car(vlax-invoke entObj 'Offset (- dist)))
						      dlg_1   (vla-Get-Length vlaObj1)
						      dlg_2   (vla-Get-Length vlaObj2))
					  ((equal (vla-Get-ObjectName entObj) "AcDbCircle")
						      dlg_1   (vla-Get-Circumference vlaObj1)
						      dlg_2   (vla-Get-Circumference vlaObj2))
					  ((equal (vla-Get-ObjectName entObj) "AcDbArc")
						      dlg_1   (vla-Get-ArcLength vlaObj1)
						      dlg_2   (vla-Get-ArcLength vlaObj2))
					  (T (princ "\nAre you crazy?!? This object comes from Mars - don't touch this!"))
				);cond
				(if (and vlaObj1 vlaObj2)
						(if (= par_wz 1)
							(if (< dlg_1 dlg_2) (vla-delete vlaObj2) (vla-delete vlaObj1) )
							(if (> dlg_1 dlg_2) (vla-delete vlaObj2) (vla-delete vlaObj1) )
						);if
						(setq objOffset (entlast))
					);prrogn
				);if
			);progn
				(command "_offset" dist (vlax-vla-object->ename entObj) insPt "")
			);progn
		);if
		(setvar "OSMODE" oldSNAP)(princ)
	);progn
);if
objOffset
);zk:Offset
RUN:
or
(zk:Offset (vlax-ename->vla-object (car(entsel))) 20.0 1 nil)
and I have question about SPLINE - this object haven't "Length" property... :
Command: (vlax-dump-object vlaobj1)
; IAcadSpline: AutoCAD Spline Interface
; Property values:
; Application (RO) = #
; Area (RO) = 21551.3
; Closed (RO) = 0
; ControlPoints = (1305.96 1023.88 0.0 1307.02 1031.16 0.0 ... )
; Degree (RO) = 3
; Document (RO) = #
; EndTangent = AutoCAD.Application: General modeling failure
; FitPoints = nil
; FitTolerance = 0.0
; Handle (RO) = "2DC"
; HasExtensionDictionary (RO) = 0
; Hyperlinks (RO) = #
; IsPeriodic (RO) = 0
; IsPlanar (RO) = -1
; IsRational (RO) = 0
; Knots = (267.117 267.117 267.117 267.117 293.057 293.057 ... )
; Layer = "0"
; Linetype = "ByLayer"
; LinetypeScale = 1.0
; Lineweight = -1
; Material = "ByLayer"
; NumberOfControlPoints (RO) = 40
; NumberOfFitPoints (RO) = 0
; ObjectID (RO) = 2129103776
; ObjectName (RO) = "AcDbSpline"
; OwnerID (RO) = 2129095928
; PlotStyleName = "ByLayer"
; StartTangent = AutoCAD.Application: General modeling failure
; TrueColor = #
; Visible = -1
; Weights = AutoCAD.Application: No weights available for polynomial spline
T
but:
Command: _list
Select objects: 1 found
Select objects:
SPLINE Layer: "0"
Space: Model space
Handle = 2ac
Length: 2081.5120
Order: 4
Properties: Planar, Non-Rational, Non-Periodic
Parametric Range: Start 0.0000
End1864.9942
Number of control points: 7
Control Points: X = 1254.1609, Y = 883.1064 , Z = 0.0000
X = 978.9713 , Y = 826.5475 , Z = 0.0000
X = 1463.5260, Y = 2025.8431, Z = 0.0000
X = 2002.1848, Y = 1239.5131, Z = 0.0000
X = 2038.4173, Y = 1933.1067, Z = 0.0000
X = 2300.6016, Y = 1919.6280, Z = 0.0000
X = 2356.5996, Y = 1900.6565, Z = 0.0000
Number of fit points: 5
User Data: Fit Points
X = 1612.9939, Y = 1645.7289, Z = 0.0000
X = 1913.4625, Y = 1472.8966, Z = 0.0000
X = 2179.3448, Y = 1894.1753, Z = 0.0000
Fit point tolerance: 1.0000E-10
Start Tangent
X = -0.9795 , Y = -0.2013 , Z = 0.0000
End Tangent
X = 0.9471 , Y = -0.3209 , Z = 0.0000
it's only way to get this parametr is:
Command: (getvar "PERIMETER")
2081.51
exist alternative way??
  • 8 years later...
 (if
   (cond
   (if (= par_wz 1)
     (if (< dlg_1 dlg_2)
     (if (> dlg_1 dlg_2)
@Lee Mac, What about AcDbxline ? i want to offset xline. Please help me!!
How are you making the xline in the 1st place if 2 points then calculate a direction dummy point that is based on the offset value + or -. You imply the direction via the two pick points.
  • Thanks 1
