stevsmith Posted July 4, 2011 Posted July 4, 2011 We use the nesting software Tru-Tops to program our laser and punch department and I have notice how handy one of the options on it is. (even though the rest of the program is utter garbage) When using the CAD software there is an option to create a construction line paralel to a specific line with an infinite length that will erase automatically after closing the drawing. With autocad this can be very annoying to draw a construction line pick 2 points then offset and delete the original construction line. So. to get to the point. I'm looking to see if one of my friendly lisp'ers out there would be willing to write me a lisp for this. The sequence should be as follows. Command start "oset" Select the line to offset (this will create a construction line with infinite line length paralell to the selected line) Enter the offset distance. Hit enter to place the line desired distance from the original Created construction layer will be on " Construction Line" layer. Thanks in advance. Stevie. Quote
Lee Mac Posted July 4, 2011 Posted July 4, 2011 This uses a slightly different approach, but perhaps it might be useful: (defun c:oset ( / *error* e orth xl ) (defun *error* ( msg ) (if orth (setvar 'ORTHOMODE orth)) (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*") (princ (strcat "\n** Error: " msg " **"))) (princ) ) (setq orth (getvar 'ORTHOMODE)) (setvar 'ORTHOMODE 1) (while (progn (setvar 'ERRNO 0) (setq e (car (entsel "\nSelect Line: "))) (cond ( (= 7 (getvar 'ERRNO)) (princ "\nMissed, Try Again.") ) ( (eq 'ENAME (type e)) (if (eq "LINE" (cdr (assoc 0 (setq e (entget e))))) (progn (setq xl (entmakex (list (cons 0 "XLINE") (cons 100 "AcDbEntity") (cons 100 "AcDbXline") (cons 8 "Construction Line") (assoc 10 e) (cons 11 (polar '(0. 0. 0.) (angle (cdr (assoc 10 e)) (cdr (assoc 11 e))) 1. ) ) ) ) ) (command "_.ucs" "_OB" (cdr (assoc -1 e)) "_.move" xl "" "_non" (trans (mapcar '(lambda ( a b ) (/ (+ a b) 2.)) (cdr (assoc 10 e)) (cdr (assoc 11 e))) 0 1) pause "_.ucs" "_P" ) ) (princ "\nObject must be a Line.") ) ) ) ) ) (setvar 'ORTHOMODE orth) (princ) ) Quote
Lee Mac Posted July 4, 2011 Posted July 4, 2011 Here is another possible method, using a coordinate transformation to make the offset easier: (defun c:oset ( / di ln nm p1 ) (if (and (setq ln (ssget "_+.:E:S" '((0 . "LINE")))) (setq di (getreal "\nSpecify Offset Distance: ")) ) (progn (setq ln (entget (ssname ln 0)) nm (mapcar '- (cdr (assoc 10 ln)) (cdr (assoc 11 ln))) p1 (trans (cdr (assoc 10 ln)) 0 nm) ) (entmake (list (cons 0 "XLINE") (cons 100 "AcDbEntity") (cons 100 "AcDbXline") (cons 8 "Construction Line") (cons 10 (trans (list (+ (car p1) di) (cadr p1) (caddr p1)) nm 0)) (cons 11 (trans '(0. 0. 1.) nm 0)) ) ) ) ) (princ) ) Specify a positive distance to offset to the right of the line, negative for the left. Quote
stevsmith Posted July 5, 2011 Author Posted July 5, 2011 Superb work once again lee. Exactly what I require. Thanks Bud. Quote
BIGAL Posted July 6, 2011 Posted July 6, 2011 Another way to not save anything temporary not limited to xlines then but user must obey layer rules, is to reprogram the "save" "close" commands so you run a delete layer first then a normal save. You can do it easy in the menu's, also in pgp. Quote
Abrasive Posted June 26, 2022 Posted June 26, 2022 (edited) On 7/4/2011 at 9:22 AM, Lee Mac said: Here is another possible method, using a coordinate transformation to make the offset easier: (defun c:oset ( / di ln nm p1 ) (if (and (setq ln (ssget "_+.:E:S" '((0 . "LINE")))) (setq di (getreal "\nSpecify Offset Distance: ")) ) (progn (setq ln (entget (ssname ln 0)) nm (mapcar '- (cdr (assoc 10 ln)) (cdr (assoc 11 ln))) p1 (trans (cdr (assoc 10 ln)) 0 nm) ) (entmake (list (cons 0 "XLINE") (cons 100 "AcDbEntity") (cons 100 "AcDbXline") (cons 8 "Construction Line") (cons 10 (trans (list (+ (car p1) di) (cadr p1) (caddr p1)) nm 0)) (cons 11 (trans '(0. 0. 1.) nm 0)) ) ) ) ) (princ) ) Specify a positive distance to offset to the right of the line, negative for the left. @Lee Mac I know this an old post.... Could this be modified to select other entities? Like polylines and other xLines? I use this now but have changed the di to static values. I use common offsets and its a pain to have to enter the value every time, but this routine works nicely. Thanks Tom Edited June 26, 2022 by Tom Matson Quote
exceed Posted June 26, 2022 Posted June 26, 2022 (edited) 2 hours ago, Tom Matson said: @Lee Mac I know this an old post.... Could this be modified to select other entities? Like polylines and other xLines? I use this now but have changed the di to static values. I use common offsets and its a pain to have to enter the value every time, but this routine works nicely. Thanks Tom (vl-load-com) (defun c:oset ( / di ln nm p1 lno lntype pt1 pt2 polycoord polycoordlen ) (if (and (setq ln (ssget "_+.:E:S" '((0 . "*LINE")))) (setq di (getreal "\nSpecify Offset Distance: ")) ) (progn (setq lno (vlax-ename->vla-object (ssname ln 0))) (setq lntype (vlax-get-property lno 'EntityName)) (cond ((= lntype "AcDbLine") (setq pt1 (vlax-safearray->list (vlax-variant-value (vlax-get-property lno 'StartPoint)))) (setq pt2 (vlax-safearray->list (vlax-variant-value (vlax-get-property lno 'EndPoint)))) ) ((= lntype "AcDbXline") (setq pt1 (vlax-safearray->list (vlax-variant-value (vlax-get-property lno 'BasePoint)))) (setq pt2 (vlax-safearray->list (vlax-variant-value (vlax-get-property lno 'SecondPoint)))) ) ((= lntype "AcDbPolyline") (setq polycoord (vlax-safearray->list (vlax-variant-value (vlax-get-property lno 'coordinates)))) (setq polycoordlen (length polycoord)) (setq pt1 (list (car polycoord) (cadr polycoord) 0.0)) (setq pt2 (list (nth (- polycoordlen 2) polycoord) (last polycoord) 0.0)) ) ) (setq nm (mapcar '- pt1 pt2)) (setq p1 (trans (cdr pt1) 0 nm)) (entmake (list (cons 0 "XLINE") (cons 100 "AcDbEntity") (cons 100 "AcDbXline") (cons 8 "Construction Line") (cons 10 (trans (list (+ (car p1) di) (cadr p1) (caddr p1)) nm 0)) (cons 11 (trans '(0. 0. 1.) nm 0)) ) ) ) ) (princ) ) like this? Edited June 26, 2022 by exceed 1 Quote
mhupp Posted June 26, 2022 Posted June 26, 2022 FYI (setq pt1 (vlax-safearray->list (vlax-variant-value (vlax-get-property lno 'BasePoint)))) (setq pt1 (vlax-get lno 'BasePoint)) 1 Quote
Abrasive Posted June 26, 2022 Posted June 26, 2022 1 hour ago, exceed said: (vl-load-com) (defun c:oset ( / di ln nm p1 lno lntype pt1 pt2 polycoord polycoordlen ) (if (and (setq ln (ssget "_+.:E:S" '((0 . "*LINE")))) (setq di 10 (getreal "\nSpecify Offset Distance: ")) ) (progn (setq lno (vlax-ename->vla-object (ssname ln 0))) (setq lntype (vlax-get-property lno 'EntityName)) (cond ((= lntype "AcDbLine") (setq pt1 (vlax-safearray->list (vlax-variant-value (vlax-get-property lno 'StartPoint)))) (setq pt2 (vlax-safearray->list (vlax-variant-value (vlax-get-property lno 'EndPoint)))) ) ((= lntype "AcDbXline") (setq pt1 (vlax-safearray->list (vlax-variant-value (vlax-get-property lno 'BasePoint)))) (setq pt2 (vlax-safearray->list (vlax-variant-value (vlax-get-property lno 'SecondPoint)))) ) ((= lntype "AcDbPolyline") (setq polycoord (vlax-safearray->list (vlax-variant-value (vlax-get-property lno 'coordinates)))) (setq polycoordlen (length polycoord)) (setq pt1 (list (car polycoord) (cadr polycoord) 0.0)) (setq pt2 (list (nth (- polycoordlen 2) polycoord) (last polycoord) 0.0)) ) ) (setq nm (mapcar '- pt1 pt2)) (setq p1 (trans (cdr pt1) 0 nm)) (entmake (list (cons 0 "XLINE") (cons 100 "AcDbEntity") (cons 100 "AcDbXline") (cons 8 "Construction Line") (cons 10 (trans (list (+ (car p1) di) (cadr p1) (caddr p1)) nm 0)) (cons 11 (trans '(0. 0. 1.) nm 0)) ) ) ) ) (princ) ) like this? Getting an Invalid parameter? Quote
exceed Posted June 26, 2022 Posted June 26, 2022 Just now, Tom Matson said: Getting an Invalid parameter? change (setq di 10 (getreal "\nSpecify Offset Distance: ")) to (setq di (getreal "\nSpecify Offset Distance: ")) maybe this point Quote
Abrasive Posted June 26, 2022 Posted June 26, 2022 Hmmm, Its actually taking the (end X) - (end Y) - (typed offset value) = offset Quote
