Error when importing .txt file - points - HELP!!!
Good Afternoon, I wonder if anybody can help me.
I have a .txt file wich I need to import.
The file is space / tab delimited.
I get an error when I want to add the file to the source files to import window
The error says:
Error Parsing value in line one.
Value B: Invalid characters found in input string 'B'
The message caries on for each different description in line one.
I don't know what the problem is with the way the file is written.
Can somebody please assist me.
Thanx
OB FOUNDATION SURVEY 17 SEPT.txt
SURVEY OF CONCRETE PLACED ON THE OUTLET BLOCK 29 SEPT-5 OCT(SVD 06 OCT) O.txt
I don't know for sure, but I don't think C3D supports alphanumeric point numbers.
Hi,
I've the same problem. My solution is a simple cut and paste to the file Importing Points.txt that i'm sending. Why does it work an what is the difference?. Hwo Knows?
Yes rkmcswain is right. You can get rid of it in excel by using the text to columns function and then remove the first column.
Or if you want the character in your point number to display in your drawing you can use HawsEDC Survey Points Import to bring in "points", but they won't be real Civil 3D points. You can still use them to build a surface though by first moving them to the proper elevation (surfaces > utilities > moves blocks to attribute elevation) and then expanding your surface data collection and add them as "drawing objects".
A simple way to edit would be to open in word change " "(spaces) to , ie csv file also if you search replace for B replace with nothing B is gone
  • 4 years later...
hi
build this format for your poins DENZ(space dilimited) in point fileformat .
in PENZ , P can read digit only but this new format solve your problem;)
You could also simply ignore the first column, by setting it as "unused":
And perhaps C3D have evolved to the better in four years? :thumbsup:
Yup, but as we tell in Italy: "Better later, than ever"...
