I am modifying a pre-existing electrical panel family and the goal is to create text on the panel in elevation view to reflect the panel name.
The issue I have seems to be that even though I type a default panel name in the "Panel Name" parameter (I used "zzz" so the value would stand out), when I load this family into a project and attempt to place my first panel, it comes in with a blank value in the "Panel Name" parameter slot. Typically, this would come in with a value of: "zzz".
Again, this is an "out of the box" family that I am attempting to modify, so I am partly wondering if this is because a something has been done to force this field come into a project empty.
Any ideas / thoughts are much appreciated.
I will also say, that once the panel is inserted, you can give it a name, then update the family to include the functionality and everything works great (because it has a name now). The problem is, getting it to come in with a default name, so you can change it after placing it into the project.
(I am using Revit MEP 2011)
Thanks,
can you upload the family file in question?
i have MEP at work, but im working from home today and only have Architecture here
Sounds like one of two things is happening...
1. There's a formula that's overriding your default value
2. You need to overwrite parameters when inserting the new (modified) family.
If these don't work, please upload the file and I'm sure we can pick it apart and fix it very quickly.
  • 1 year later...
I have spent, hours and hours trying to figure this out. It is bs as far as I can tell you can't change the default of new instances. But I'll keep searching for a solution, (this reason alone is making me regret investing in Revit 2013).
Your post was absolutely dripping with information...
When you redefine the family (i.e. you load it into your project) a dialog like this should open:
Click the 2nd option to overwrite the family's definition and ALSO its values in the parameters. If you click the 1st option, only the definition is overwritten.
Moral: Read what you're clicking on before clicking it. I've found lots of people using Revit complain about stuff "going wrong" - only to find that they tend to just click on messages / error warnings without even trying to understand why they occurred. Nearly always something not working / simply "disappearing" is because of one of those warnings which you simply clicked on the OK / Continue button without noticing that it was saying that some stuff are going to be deleted / links broken / etc. Same principle goes for this - the override dialog has 2 options, but most only read as far as the 1st few words of the 1st option.
