Insert Multiple blocks into drawing?
Oops! Excuse me, I have not checked up this code. Excessive self-confidence... Now should work (may be :wink: ):
(defun c:test2(/ blLst diFol oldAtr *error*)
 (vl-load-com)
(defun BrowseFolder(Message / ShlObj Folder FldObj OutVal)
 (setq ShlObj (vla-getInterfaceObject
                 (vlax-get-acad-object)
                   "Shell.Application")
       Folder
        (vlax-invoke-method ShlObj 'BrowseForFolder 0 Message 0)
       ); end setq
 (vlax-release-object ShlObj)
 (if Folder
     (setq
 	FldObj (vlax-get-property Folder 'Self)
 	OutVal (vlax-get-property FldObj 'Path)
     	(vlax-release-object Folder)
     	(vlax-release-object FldObj)
     OutVal
); end of BrowseFolder
(defun *error*(msg)
 (if oldAtr(setvar "ATTREQ" oldAtr))
 (setvar "CMDECHO" 1)
 ); end of *error*
; if folder selected and is drawings inside
(if(and
    (setq diFol(BrowseFolder "Select folder to insert blocks"))
    (setq blLst(vl-directory-files diFol "*.dwg" 1))
    ); end and
 (setq oldAtr(getvar "ATTREQ"))
 (setvar "CMDECHO" 0)
 (setvar "ATTREQ" 0)
 ; foreach block name in list
 (foreach bl blLst
   ; if block found in drawing database
   ; if block not found in drawing, set block name as full path
   (if(not(tblsearch "BLOCK" bl))
     (setq bl(strcat diFol "\\" bl))
     ); end if
     ; insert block in point 0,0 with scale 1 and rotation 0
     (vl-cmdf "_.-insert" bl "0,0" "1" "" "0")
   );end foreach
 ; swich on echo output
); end progn
 ; if nothing files found print error message
 (princ "\n<!> Nothing *.dwg files found <!> ")
 ); end if
 ; silent exit (without value of last expression)
); end of c:test2
  • Replies 54
  • skipsophrenic
    13
  • Lee Mac
    8
  • Strix
    7
  • EBROWN
    5
Posted Images
lisp works i think, computer don't - Ran out of virtual memory whatever that is
  Quote
200 blocks at once... May be :(
try 1566 blocks! thats why i was hoping there was a quicker way - i gave up on exploding them for now to try keep filesize down (even though that what asked for)
Did this one but not sure if it would work either.
;;  Block Import Lisp  08/12/2008
;;  CAB at TheSwamp.org
 ;;  Get user selection of folder
 ;;  Get all DWG files in folder
 ;;  INSERT dwg as block @ 0,0
 ;;  get Bounding Box of block
 ;;  Move Insert to right w/ gap between blocks
 ;;  Next Insert
(defun c:BlkImport (/ path LastDist gap space err newblk bname obj ll lr ur
              InsPt dist GetFolder)
 (vl-load-com)
 (defun GetFolder ( / DirPat msg)
  (setq msg "Open a folder and click on SAVE")
  (and
   (setq DirPat (getfiled "Browse for folder" msg " " 1))
   (setq DirPat (substr DirPat 1 (- (strlen DirPat) (strlen msg))))
  DirPat
 (defun activespace (doc)
   (if (or (= acmodelspace (vla-get-activespace doc))
           (= :vlax-true (vla-get-mspace doc)))
       (vla-get-modelspace doc)
       (vla-get-paperspace doc)
 (setq gap 20) ; this is the gap between blocks
 (setq LastDist 0.0) ; this is the cumulative distance
 (if (setq Path (GetFolder))
     (setq space (activespace (vla-get-activeDocument (vlax-get-acad-object))))
     (prompt "\n***  Working, Please wait ......\n")
     (foreach bname (vl-directory-files Path "*.dwg" 1)
       ;;  OK, try & insert the Block
       (if (vl-catch-all-error-p
             (setq err (vl-catch-all-apply
               '(lambda () (setq newblk (vla-insertBlock space
                               (vlax-3d-point '(0.0 0.0 0.0)) (strcat path bname) 1.0 1.0 1.0 0.0))
         ;;  Display the error message and block/file name
         (prompt (strcat "\n" bname " " (vl-catch-all-error-message err)))
         ;;  ELSE
         (progn ; INSERT was sucessful, move the block
           ;;  get bounding box
                 (setq err (vl-catch-all-apply 'vla-getboundingbox (list newblk 'll 'ur))))
              (prompt (strcat "\nBB Error - could not move " bname "\n  " (vl-catch-all-error-message err)))
                (setq ll (vlax-safearray->list ll)
                      ur (vlax-safearray->list ur)
                      lr (list (car ur) (cadr ll))
                      dist (distance ll lr)
                ;;  MOVE the block
                (setq ;InsPt  (vla-get-insertionpoint Newblk)
                      NewPt (polar '(0. 0. 0.) 0.0 (+ LastDist Gap (* dist 0.5)))
                      LastDist (+ LastDist Gap dist)
                (vlax-put Newblk 'insertionpoint NewPt)
(prompt "\nBlock Import Loadd, Enter BlkImport to run.")
I'll let you know when get chance to test it:)
  • 2 weeks later...
I tried the lisp above and found that it worked, with the one exception. I can't get it to default to a specific directory. I keep getting locked up since once I set the derictory path, it now assumes I want to specifiy the filename.
 (vl-load-com)
  (setq msg "C:/KMS/JOBSNT/")
  (and
   (setq DirPat (getfiled "Browse for folder" "msg" " " 1))
   (prompt Dirpat)
  DirPat
Additionally, I have a routine I want to apply the other routine to. Below is a simple LISP that I need to preform to every DXF file in a directory. It does the same exact thing every time. Once this routine has been completed for all of the DXF files in a directory, I need to insert them into the active drawings just like the other guy needed.
(defun C:3dtrs (/ tfl tpth tfilnam tfilinfo)
 (command "erase" (ssget "X" (list (cons 8 "ELEMENTS"))) "")
 (command "_pedit" "M" (ssget "X") "" "y" "J" "" "")
 (command "-purge" "La" "ELEMENTS" "N")
 (command "_extrude" (ssget "X") "" "1.75" "")
 (command "-view" "_left")
 (command "rotate" (ssget "X") "" "0,0,0" "270")
 (setq tfl (getvar "dwgname"))
 (setq tpth (getvar "dwgprefix"))
 (setq tfilnam (substr tfl 1 (- (strlen tfl) 4)))
 (setq tfilinfo (strcat tpth tfilnam ".dwg"))
 (command "saveas" "" tfilinfo)
 (command "close")
Any thoughts on how to apply this to a batch of files? Or did I just break a cardinal sin by introducing a seprate issue?
Edited by SLW210
Added Code Tags!!!!!
  • 11 months later...
To a dxf.... guess it's difficult... I would batch convert all the dxf to dwg with acme cad converter... and then apply the batch lisp... with a starting script... that will load an apply your lisp to all the drawings... I already posted the batch + starting script files.
  • 1 year later...
Is there a way to do this but for images? Insert multiple images at the same time in a draw?
You could do any of this with a script. Use the "-insert" command to suppress the dialog box. You'll need to do some prep work ahead of time so the script doesn't fail, however. All of the images, blocks, pdfs, etc will have to be in a directory with no spaces in the name, and you can't have any spaces in the filename either.
Script would look something like this:
-insert
c:\foldername\filename.jpg [i](or dwg, pdf, etc)
[/i]0,0 [i](or appropriate location[/i])
[i][leave a blank line here]
[leave second blank line here][/i]
[i][leave a third blank line here][/i]
-insert
c:\foldername\filename2.jpg [i](or dwg, pdf, etc)[/i]
0,0 [i](or appropriate location)
[/i][i][leave a third blank line here][/i]
And so on for each file. The filenames can be extracted and dumped into a comma delimited file, opened with a spreadsheet and exported to a text file where you could then paste in the rest of the stuff between the file names. The three blank lines will be interpreted as hitting the enter key three times to accept the default scale factors for x and y, and the default rotation angle of zero.
You should use a plain text editor like Notepad to construct scripts. Wordpad and other word processors sometimes have special formatting characters that will cause you grief. When you save your file be sure to click the pull down arrow on "save as type" and change that to "all files" and give your script the file extension of ".scr". If you forget to change the type of file, you'll get a text file that is named "*.scr.txt" and it won't work. All is not lost if you do that however, simply rename the file with the scr extension.
I thought there was a way like this one but for images. I have a tone of .sid to load.
  • 3 months later...
Hi Skipsophrenic,
Did you get an answer to your problem? I have the same task next week with 8400 dxf files. I would like to insert all of them in the same time in one new drawing.
Any help appreciated.
Greeteings,
Andrulex
  Andrulex said:
Hi Skipsophrenic,
Greeteings,
Andrulex
8400? Whatever for?
  Dink87522 said:
8400? Whatever for?
In shipbuilding one ship is split in sections and every section has thousands pieces.
Every piece is exported from a dedicated software as dxf file. To have an overview of this pieces i make a new drawing where I insert these components. With a script it will be much faster to insert all in once.
Why are you asking for?
Greetings,
Andrulex
Are all of the files in one folder? You could XREF them in at once, then use Xref Manager and Bind them all at once.
See if this helps.
INSERT BLOCKS
Not too different from those already posted, but try this:
(defun c:InsertAll ( / cmd dir extn )
   (setq extn "dxf") ;; Extension of files to Insert e.g "dwg"
   (if (setq dir (LM:DirectoryDialog (strcat "Select Directory of " (strcase extn) " Files to Insert") nil 512))
           (setq cmd (getvar 'CMDECHO))
           (setvar 'CMDECHO 0)
           (foreach file (vl-directory-files dir (strcat "*." extn) 1)
               (vl-cmdf "_.-insert" (strcat dir "\\" file) "_S" 1.0 "_R" 1.0 "_non" '(0 0 0))
           (setvar 'CMDECHO cmd)
       (princ "\n*Cancel*")
;;-------------------=={ Directory Dialog }==-----------------;;
;;  Displays a dialog prompting the user to select a folder   ;;
;;  Author: Lee Mac, Copyright © 2011 - www.lee-mac.com       ;;
;;  Arguments:                                                ;;
;;  msg  - message to display at top of dialog                ;;
;;  dir  - root directory (or nil)                            ;;
;;  flag - bit coded flag specifying dialog display settings  ;;
;;  Returns:  Selected folder filepath, else nil              ;;
(defun LM:DirectoryDialog ( msg dir flag / Shell Fold Self Path )
   (vl-catch-all-apply
       (function
           (lambda ( / ac HWND )
               (if
                   (setq Shell (vla-getInterfaceObject (setq ac (vlax-get-acad-object)) "Shell.Application")
                         HWND  (vl-catch-all-apply 'vla-get-HWND (list ac))
                         Fold  (vlax-invoke-method Shell 'BrowseForFolder (if (vl-catch-all-error-p HWND) 0 HWND) msg flag dir)
                   (setq Self (vlax-get-property Fold 'Self)
                         Path (vlax-get-property Self 'Path)
                         Path (vl-string-right-trim "\\" (vl-string-translate "/" "\\" Path))
   (if Self  (vlax-release-object  Self))
   (if Fold  (vlax-release-object  Fold))
   (if Shell (vlax-release-object Shell))
   Path
(vl-load-com) (princ)
DirectoryDialog function from here.
Edited by Lee Mac
I use this from time-to-time...
(defun c:InsertAll (/ _bbUL _bbUR space temp dir lst)
 ;; Insert all file(s) of specified type and within directory of selected file
 ;; Alan J. Thompson
 (defun _bbUL (o / a b)
   (vla-getboundingbox o 'a 'b)
   (list (car (vlax-safearray->list a)) (cadr (vlax-safearray->list b)) 0.)
 (defun _bbUR (o / a b) (vla-getboundingbox o 'a 'b) (vlax-safearray->list b))
 (setq space (vlax-get (cond (*AcadDoc*)
                             ((setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object))))
                       (if (eq (getvar 'CVPORT) 1)
                         'paperspace
                         'modelspace
 (if (setq temp (getfiled "Select file type to import" (getvar 'DWGPREFIX) "" 2))
                   (setq dir (vl-filename-directory temp))
                   (strcat "*" (vl-filename-extension temp))
                   1
     (if (cadr (setq lst
                      (cons (vlax-invoke
                              space
                              'insertblock
                              '(0. 0. 0.)
                              1.
                              1.
                              1.
                              0.
                            lst
       (vlax-invoke (car lst) 'move (_bbUL (car lst)) (mapcar '+ (_bbUR (cadr lst)) '(1. 0. 0.)))
Thank you Lee Mac. This works very good. If i may dare to ask you a last question: now, all dxf's are inserted in the same insertion point overlapping one over each other. There are hundreds of small plates in this case. Is it possible to "arrange" every block let's say on Y axis within a specified distance between them? A sort of routine "block arrangement". Only if this is not too complicated. Thank you in advance.
Regards,
Andrulex
Not too difficult to incorporate, give this a try:
(defun c:InsertAll ( / cmd dir extn pt vec )
   (if
       (and
           (setq vec (getpoint "\nPick Spacing Vector: " '(0 0 0)))
           (setvar 'CMDECHO 0)
           (setq pt '(0 0 0))
               (vl-cmdf "_.-insert" (strcat dir "\\" file) "_S" 1.0 "_R" 1.0 "_non" pt)
               (setq pt (mapcar '+ pt vec))
;;  Arguments:                                                ;;
   (vl-catch-all-apply
       (function
               (if
   Path
I hope the use of the 'Spacing Vector' is clear and understandable.
Edited by Lee Mac
Thank you Lee Mac,
Yes, everything is clear and perfect understandable. It saves a lot of time.
Greetings,
Andrulex
