I had asked such in another location here w/o luck. But how do I convert a font of *.shx in to a font of *.shp format? Used to be a simple command, but forgot it now.
Wm.
DUMPSHX.EXE run from the OS command line
If you are not used to accessing the OS command line and running DOS-like procedures, post the SHX file and I will convert it for you.
  • 3 months later...
Is there a way to convert and open font (Lithos Pro) to a shx font? or is there already a similar font available?
