Hello All,
I tried to solve a problem lisp and DCL but it is clear that I have a lot to learn. With lisp's trying to insert text in Autocad list opens (see DCL).:cry:
Any help is welcome.
Dialog Text.zipUnavailable
There are a few issues
You don’t always need to use wildcard characters in a variable name (*variable%)
Some of the set_tile calls are to tiles that are not there
You need to clean up the dcl call section
Use the autocad visual editor to debug the file
If needed read the autocad help file in the visual lisp editor
