doru10 Posted June 14, 2011 Posted June 14, 2011 Hello All, I tried to solve a problem lisp and DCL but it is clear that I have a lot to learn. With lisp's trying to insert text in Autocad list opens (see DCL). Any help is welcome. Dialog Text.zipFetching info... Quote
JohnM Posted June 14, 2011 Posted June 14, 2011 There are a few issues You don’t always need to use wildcard characters in a variable name (*variable%) Some of the set_tile calls are to tiles that are not there You need to clean up the dcl call section Use the autocad visual editor to debug the file If needed read the autocad help file in the visual lisp editor Quote
