export curved surface from 3DS MAX to Autocad/Inventor
Hello. I have a curved surface and I don't know a right way to export it.
If it like Editable Poly then I have a mesh in DWG. Then I set to Faceted and optimized then merge faces (to receive one face) and then convert to surface but after that I have a surface with multiple triangles. This is one way which I use, I tried many ways but I have the same results.
This is what I have after export from 3DS MAX (same as DWG, SAT, IGS)
This is what I receive from splines and loft in AUTOCAD.
My friend have several versions of Autocad (2009, 2011, 2012), Inventor (2011, 2012) and 3DS MAX (9, 2012). And I think it is no problem to use trial software of other versions.
I have 8 Gb of RAM, then I convert big mesh objects to surface I have out of memory, long time process and finally message that object can not be converted.
Why are you making this in Max and then exporting it to Autocad? Autocad 2012 has mesh modeling tools so why don't you just make it there? And I really don't know why you would want to take it into Inventor? What is this for?
Designer uses 3DS MAX 9 and he never worked in CAD software.
This is an Autocad question, not a Studio Max question.
I have moved this thread to the Autocad 3D section.
