In Autocad LT 2007 i push mouse wheel for panning and when releasing the button i get the copyclip command. This stops the command that i was in. It started when i put the Autocad on Windows 7 system. What can cause this?
I have 2 computers running with windows 7 both with AutoCAD, but both with an other mouse, one has the same problem when I switch the mouse the problem is gone. So I would say it's a mouse problem or mouse driver problem.
Allready tried this. Even uninstalled the mouse driver and intall again. Nothing help.
Try changing "MBUTTONPAN" to 1.
Plugin an other type of mouse, lets see if that works
Checked "MBUTTONPAN". All the time on 1. Tried also another mouse.
What mouse are you using?
What mouse software are you using?
Are you running AutoCAD on a WinXP virtual machine inside Win7?
Have you tried it without any mouse software at all (using only the Win7 generic mouse driver) ?
I am using Logitech mouse with generic mouse driver of win7.
I tried also Microsoft mouse with its software.
The Autocad is running on Win7 with compability to WinXP.
We found the solution. The problem was one of the services that windows run at the startup. When we tried to solve a problem in Office software, we disabled some services in the startup and apparently one of them was the problem.
I'm sorry, but i don't know which of them.
