Hi,
I'm having a Gizmo problem, and it has been recurring for a long time.
Problem:
When I select an object, either with scale/rotate/move selected, the corresponding Gizmo appears
Great:shock:
But as I hover my cursor over it, and it clearly shows I'm over it by changing color, and try to click on it. It disappear.
It's very frustrating as I try to click on it, and it's gone, and the command window displays this message
"Please select an axis" duhhh :(I can't cuz the Gizmo is GONE. Then I ended not being able to perform all those functions.
Any idea guys?
Regards,
Dulerong
Actually guys,
I found my solution, it's really weird but in case someone with the same problem.
To avoid this:
In 3D mode, Home->Selection then you can see gizmo selection types (scale, rotate, move)
Basically the problem I was having is due to selecting the different gizmo then what I intended to do,
so like this: type "rotate" but had "scale" selected in that tab.
This is not gonna work.
Hope it helps anyone like me.
Hi,
Is that the exact message? None of my gizmos in 2011 prompt for an "axis" before, during, or after using the gizmo.
Not sure I understand, but I'm glad you figured it out.
You may want to look into the GTDEFAULT variable, if you have it enabled (1), it should present the correct Gizmo, even if you invoke a 2D command (ie rotate / move / scale) while you're in a 3D view, regardless of which gizmo is selected on that Ribbon tab.
i've managed to fix this problem with manually typing in 3Dmove, 3Dscale, 3Drotate,
For some reason this problem still persists
I just can't select an object and use the GIZMO right away, like I need to type in the command
Thanks for the help guys!
Try reading the help files.....
From Help
Gizmos are available only in 3D views that are set to use a 3D visual style such as 3D Hidden. You can set the gizmo to be displayed automatically when you select a 3D object or subobject. Gizmos are also displayed during the 3DMOVE, 3DROTATE, and 3DSCALE commands.
If the visual style is set to 2D Wireframe, entering 3DMOVE, 3DROTATE, or 3DSCALE automatically converts the visual style to 3D Wireframe.
By default, the gizmo is initially placed in the center of the selection set. However, you can relocate it anywhere in 3D space. The center box (or base grip) of the gizmo sets the base point for the modification. This behavior is equivalent to temporarily changing the position of the UCS as you move or rotate the selected objects. The axis handles on the gizmo constrain the movement or rotation to an axis or plane.
It sounds to me like you're executing a command line command. The gizmo works when you select an object, then that gizmo suddenly appears around the centre of that mass. Then you select one (or more) axis, whether it's move, scale, or rotate. No typing necessary with the gizmo.
