All,
How should I go about verifying that an item in one list does not appear in another list?
Kind Regards,
Matt
by function *member* you can check that out .
(setq lst1 '(1 2 3 4 5 ))
(setq lst2 '(6 7 8 9 10))
(setq a (not (member 8 lst1 )))
An example of a function to return the 'intersection' of two lists:
(defun LM:ListIntersection ( l1 l2 )
 (if l1
   (if (member (car l1) l2)
     (cons (car l1) (LM:ListIntersection (cdr l1) l2))
And its complement, the 'union' of two lists:
(defun LM:ListUnion ( l1 l2 )
 ( (lambda ( f ) (f (append l1 l2)))
   (lambda ( l ) (if l (cons (car l) (f (vl-remove (car l) (cdr l))))))
My versions:
= List:UniqueP =
Test if a list contains only unique elements
=== Arguments ===
L: The source list
=== Result ===
T if unique list, nil otherwise
(defun List:UniqueP (L /)
 (while (and L (not (vl-position (car L) (cdr L)))) (setq L (cdr L)))
 (not L)
= List:Unique =
Ensure only unique values in list.
=== Arguments ===
L: The source list
=== Result ===
A new list containing only unique elements from source
(defun List:Unique (L /)
 (if (cdr L)
   (if (vl-position (car L) (cdr L))
     (List:Unique (cdr L))
     (cons (car L) (List:Unique (cdr L)))
   L
= List:Subtract =
Removes elements from one list if they are in another.
=== Arguments ===
L1: The source list
L2: The list to subtract from L1
=== Result ===
A new list containing all elements of L1 which were not in L2
(defun List:Subtract (L1 L2 /)
 (vl-remove-if '(lambda (item) (vl-position item L2)) (List:Unique L1))
= List:Union =
Combines 2 lists together
=== Arguments ===
L1, L2: The 2 source lists
=== Result ===
A new list containing all elements of L1 and L2 - no duplicates
(defun List:Union (L1 L2 /)
 (append (List:Subtract (List:Unique L1) (setq L2 (List:Unique L2))) L2)
= List:Intersect =
Intersects 2 lists together
=== Arguments ===
=== Result ===
A new list containing all elements found in both L1 and L2 - no duplicates
(defun List:Intersect (L1 L2 /)
 (vl-remove-if-not '(lambda (item) (vl-position item L2)) (List:Unique L1))
