CAnnondale Posted June 3, 2011 Share Posted June 3, 2011 Hi Guys, I do have a query though I have been straggling to do this drawing views in Inventor for quite sometime now. Can Autodesk Inventor do a sectional 3D View in .idw? If so can you please guide me on how to do it... Appreciate any assistance. I do want to create a sectional view without the need to cut may actual part drawing. I do want to show the cutting section only in the drawing template. I have attached a jpg for reference. Quote Link to comment Share on other sites More sharing options...
rdharvey Posted June 3, 2011 Share Posted June 3, 2011 Yes it can... when you are in the drawing environment select the place view tab and then section and choose your desired planes or what ever to cut the section. Quote Link to comment Share on other sites More sharing options...
rdharvey Posted June 3, 2011 Share Posted June 3, 2011 (edited) Ah in an isometric view.. i am unsure. i'll have a quick go n see if i can get it to work. The way i have been doing it is doing a section of a 2d view. and then projecting a view from there.... hope this gives you what you need. Edited June 3, 2011 by rdharvey found a solution Quote Link to comment Share on other sites More sharing options...
rdharvey Posted June 3, 2011 Share Posted June 3, 2011 Quote Link to comment Share on other sites More sharing options...
CAnnondale Posted June 4, 2011 Author Share Posted June 4, 2011 Hi rdharvey, Thanks for the info. Appreciate it. I will give it a try. Quote Link to comment Share on other sites More sharing options...
CAnnondale Posted June 4, 2011 Author Share Posted June 4, 2011 Hahahaha... Nice rap man... It is in-deed a very useful rapping teaching... Thanks for Sharing Quote Link to comment Share on other sites More sharing options...
rdharvey Posted June 16, 2011 Share Posted June 16, 2011 Did you manage to get the outcome you needed for your project? Quote Link to comment Share on other sites More sharing options...
CAnnondale Posted June 24, 2011 Author Share Posted June 24, 2011 Did you manage to get the outcome you needed for your project? Hi Rapper ROB, Sorry for the late reply. Yes I did manage to get the 3D sectional view using the RAPPING TUTZ technique. Thank you very much. Quote Link to comment Share on other sites More sharing options...
