Raudel Solis Posted June 1, 2011 Posted June 1, 2011 when ever i create an object the xyz move gizmo appears and i dont want it to appear, also when i try to create a window by using snaps it is not made correctly because one value stays at 0 lets say lenght stays at 0 it recently happened, i think i hit a hotkey on accident it was working fine until the xyz gizmo started appearing. Quote
Cad64 Posted June 2, 2011 Posted June 2, 2011 That seems odd. Never had that happen before. When you say it recently happened, do you mean a few hours ago or a few days ago? Have you tried closing Max and restarting? Is it possible that maybe you changed the default Position Controller? Try this: Select any object Go to the Command Panel > Motion Tab Expand the "Assign Controller" rollout Expand the object’s "Transform: Position" and click on the one for Position to highlight it Click the "Assign Controller" button Check the list and make sure “Position XYZ” is selected. If it's not, click it and then click the "Make Default" button Quote
Raudel Solis Posted June 2, 2011 Author Posted June 2, 2011 thanks for the reply, I tried but the issue remained, i ended up resetting max forgetting that i had not saved :/, the drawing is gone and so is the problem Quote
Cad64 Posted June 2, 2011 Posted June 2, 2011 Sometimes Max just freaks out and does weird things. Closing it down and then restarting it usually gets things back to normal. Quote
