striker0911 Posted May 26, 2011 Posted May 26, 2011 Hey guys, I have a problem I created some drawings and made them XREF everything works fine until i try plotting them, the objects that are on the main drawing plot just fine but the XREF for some reason comes out faded not as vivid as i would like them to be. I already updated the drivers for my plotted it's an HP Design Jet 1050c it's an old one but the problem only exits when plotting drawings with an XREF can some one please help me out:cry:? THANK YOU!! Quote
SLW210 Posted May 26, 2011 Posted May 26, 2011 What settings do you have on the fading of your xref? Maybe you have them on a layer with transparency, or have the xref faded. What plot setting do you have set? Are you fading some colors in your CTB? Quote
striker0911 Posted May 26, 2011 Author Posted May 26, 2011 the setting that i have for the xref fading are 0, i don't have any transparency for any of the layers and for my plot settings im using the default CTB i haven't modified any of those settings Quote
