magic_man1 Posted May 23, 2011 Share Posted May 23, 2011 I have done a fair amount of scouring the internet for a solution, to no avail, hopefully someone here can help me. For example, I have a hosted electrical receptacle device with a loaded annotation (2D symbol for printed plan purposes). What I would like to do is add a horizontal annotation offset that allows me to move the symbol left OR right based upon a single properties window field. As it sits right now, I have a reference line to one side of my device center line that is tied to a dimension parameter. Unfortunately Revit does not allow negative lengths, which means moving the annotation in the opposite direction is not possible. I have even tried (without expecting it to work) locking my annotation to two different reference lines (a right and a left parameter), but this produces no change at all. I believe this is because it can't be locked to two parameters, with different values, at the same time. One of the threads I read (http://www.revitcity.com/forums.php?action=viewthread&thread_id=15532) makes mention of this functionality, but does not go into detail on how to make this happen. Given that this thread was quite old, I did not ask this question on that forum yet, but I might. Any help you can give is much appreciated. FYI.. I am using Revit MEP 2011. Quote Link to comment Share on other sites More sharing options...
Lee Roy Posted May 23, 2011 Share Posted May 23, 2011 Make two identical labels in the annotation family. Assign visibility to a yes/no parameter. For instance, make your standard label on the left side, make a yes/no property that makes visible a copy of the label on the right side. Then a formula for the left-side label that turns it off when the yes/no returns a 'true' value. Both labels can locate off the same length dimension (from centerline) property, just visibility is controlled by one yes/no parameter. I'm at home now, but I can scratch up an annotation symbol when I get to work in morning, for a better idea of what I'm saying...or you can just use it and tweak it to your liking, if you want. I hope I make sense. I know things work right in my head, but putting them into words hardly ever works right; I stumble a lot and leave things out. Quote Link to comment Share on other sites More sharing options...
