Rewind23 Posted May 22, 2011 Share Posted May 22, 2011 Hi Guys, i need assistance.... i am currently working with my ground floor plan..from ACAD2011 i import the plan to SU Pro 7.1 for the 3D modelling...i converted it to .DXF format because when i import using .DWG, the file got errors...i already selected ARCHITECTURAL - Millimeters as my template...so when i started the tracing and use the PUSH/PULL command when i type, lets say the height of the wall should be 3,000mm(in my drawing) the extrusion of the wall didnt seem 3,000mm.maybe i just need to adjust some settings but im just new to SU..im currently idle with this drawing...your quick help is appreciated..any suggestion? Thanks in Advance! Quote Link to comment Share on other sites More sharing options...
soumya Posted June 6, 2011 Share Posted June 6, 2011 Hi, I faced the same problem. It happens because when you import your CAD in Sketchup, by default sketchup takes feet as import unit. So, click import > options > and then change the unit to millimeters (also check the 'Preserve drawing origin') check out this link for details SketchUp Help http://bit.ly/jneoWB Quote Link to comment Share on other sites More sharing options...
Rewind23 Posted June 13, 2011 Author Share Posted June 13, 2011 Hi,I faced the same problem. It happens because when you import your CAD in Sketchup, by default sketchup takes feet as import unit. So, click import > options > and then change the unit to millimeters (also check the 'Preserve drawing origin') check out this link for details SketchUp Help http://bit.ly/jneoWB hi thanks for that link & information..i find it useful... Quote Link to comment Share on other sites More sharing options...
wakozi Posted July 9, 2011 Share Posted July 9, 2011 Hi,I faced the same problem. It happens because when you import your CAD in Sketchup, by default sketchup takes feet as import unit. So, click import > options > and then change the unit to millimeters (also check the 'Preserve drawing origin') check out this link for details SketchUp Help http://bit.ly/jneoWB now i know why. i usually just import everything directly to sketchup and then scale the model so that i get the right dimensions. this is very helpful thanks. Quote Link to comment Share on other sites More sharing options...
