Hi all,
Is there a way to find which points creates a closed polygon among a set of points.
I have a list of points, Using that points i want to create a closed polygon.
here no need to use all points. Need to use only those points which will creates a closed polygon.
for ex:
the following points will create a self inspecting polyline
X= 1.0715 Y= 2.2652
X= 1.0547 Y= 3.5137
X= 1.0293 Y= 5.5300
X= 2.5485 Y= 5.8253
X= 3.1308 Y= 4.3405
X= 0.1263 Y= 3.8849
From this i am excepting the following result, which is a closed part in the self intersecting polyline.
((1.04825 4.02473)(1.02935 5.52999)(2.54849 5.82526)(3.13082 4.34049))
Thanks,
Kumar.:o
Any three non-collinear points will form a closed polygon (triangle).
I think my explanation is not clear.
Please refer the snap shot.
i have self intersected poly line. from that i want extract vertices for only closed part (which is marked with red circle).
Thanks,
Kumar.
I don't believe that could be determined from just the points, since, as I stated, any combination of three points would form the closed area.
Why not just use the Boundary command to generate a new polyline inside the enclosure?
... That's what I'd do.
Thanks a lot.
I am new to autocad and not aware of boundary command.
This works great for me. :)
OOPS ................ I haven't used that in a decade. :?
