dulerong Posted May 16, 2011 Posted May 16, 2011 (edited) Hi guys, I'm using AutoCAD 2012 on ASUS WIN 7, i5, 4GB RAM, Intel HD Graphic Card. For some reason my cursor becomes very laggy and jerky as I use the "Line" tool, that being said, my cursor is completely fine when I use any other tool. http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15127843&linkID=9240617 I know in the AutoDesk "Knowledge Base" there's a similar Q&A for my situation, but after doing carry out all the AutoCad commands the cursor is still laggy. I don't have a face scanner or virus program turned on. My drivers are updated as well. So far, only "Line", "Polyline", and just about any function that involves drawing a line (eg: arc), my cursor becomes very laggy. Any help is greatly appreciated! Thank you! @ Grant - No I turned off my Virus program, and have a only AutoCAD running. Seeing my laggy problem is isolated to "Line" function, I'm thinking my problem is not a hardware/software issue, but more of a setting problem. Thank you for your reply though Grant! Edited May 16, 2011 by dulerong Quote
Grant Posted May 16, 2011 Posted May 16, 2011 Have you got something else running in the background - auto antivirus check running Goto windows task manager and click the processes tab and see what is taking the cpu time See how much ram is being used under performance tab - if it is around 75% in memory or CPU I would say that something else is using your computer time and memory Quote
Organic Posted May 16, 2011 Posted May 16, 2011 What antivirus program and/or firewall do you have installed? They are not all compatible with Autocad (shutting them down does not resolve the issue). Quote
SLW210 Posted May 16, 2011 Posted May 16, 2011 Not that I mind posting a few hundred times to try to WAG your problem, but maybe you could help things along by listing out the steps you have taken so far. Quote
tzframpton Posted May 16, 2011 Posted May 16, 2011 Is it only when you use the LINE tool? What about when you use PLINE? Same thing or no? I've heard if you are using a wireless mouse, replace the batteries. Worth a try at least, unless you're mouse is wired. Quote
irneb Posted May 16, 2011 Posted May 16, 2011 Your graphics card isn't exactly what I'd call "conducive to CAD". Try to see if you can turn on/off hardware acceleration - maybe the rubber-banding is causing hassles with your GPU. Apart from that, I've found a jerky cursor happens every now and then on my WinXP (even outside of ACad) - which requires a reboot to fix. It might have been some mouse driver issue though and would affect EVERYTHING not just 1 command in ACad. If all else fails try playing with the DragMode / DragP1 / DragP2 system variables. You might loose the rubber-band effect alltogether, but that's what you'll have to pay for using the cheap graphics card. Quote
rich75 Posted June 22, 2011 Posted June 22, 2011 i have exactly the same problem and its very annoying. Operating System MS Windows 7 64-bit CPU Intel Xeon X3430 @ 2.40GHz 28 °C Lynnfield 45nm Technology RAM 7.93 GB Dual-Channel DDR3 @ 666MHz (9-9-9-24) Motherboard Hewlett-Packard 0B40h (XU1 PROCESSOR) 7 °C Graphics Acer AL2416W (1920x1200@59Hz) NVIDIA Quadro 600 Hard Drives 488GB Hitachi Hitachi HDS721050CLA362 (RAID) 28 °C 488GB Hitachi Hitachi HDS721050CLA362 (RAID) 22 °C Optical Drives hp DVD A DH16ABLH Audio Realtek High Definition Audio have tried a number of remedies and at the moment i have decided to use an older version until i can get it sorted. Quote
rich75 Posted June 22, 2011 Posted June 22, 2011 I have solved my particular issue by turning on hardware acceleration within Acad. it is located on the bottom right of the screen. this link may also help people who are still having issues. http://forums.autodesk.com/t5/AutoCAD-2012/Extremely-slow-performance/td-p/3064338 Quote
Androidus Posted June 10, 2014 Posted June 10, 2014 Hi, If you find that nothing works, you could select all items in your drawing (Ctrl+A) and transfer (copy-paste) them in a new Autocad File. It worked for me. Quote
RobDraw Posted June 10, 2014 Posted June 10, 2014 Brilliant! Four year old post finally solved. Quote
Grant Posted June 10, 2014 Posted June 10, 2014 I find this happens when you have edited a block by double clicking on the block and using 'Edit Block Definition' on a slightly bigger drawing. When you come out of the block editor it can sometimes go laggy! The way I solve this is to: 1. don't use 'Edit Block Definition' - explode the block, do the mod, re-block 2. When it is laggy - save the drawing, close the drawing and then go back into the drawing. Not good solutions though! Quote
