tcec2010 Posted May 15, 2011 Share Posted May 15, 2011 anyone knows where to find 2d blocks for different drainage structures, such as manhole, cesspit, blank cap, valves, hydrant, etc? Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 16, 2011 Share Posted May 16, 2011 These types of blocks aren't included with Civil 3D on a Tool Palette? Two outside sources of both 2D and 3D AutoCAD blocks are the CAD Block Exchange Network and the CADforum. Quote Link to comment Share on other sites More sharing options...
designerstuart Posted May 16, 2011 Share Posted May 16, 2011 why would you want to block your drainage structures? (sorry, that was my first AutoCAD pun) Quote Link to comment Share on other sites More sharing options...
Organic Posted May 16, 2011 Share Posted May 16, 2011 These types of blocks aren't included with Civil 3D on a Tool Palette? It does come with a few base parts (not detail sheets though) although they are only examples really. You need to define your own parts depending on local specifications. For the specifications for your local area (and most likely 2D dwg files also), contact the local Council that signs off on the civil infrastructure and they will be able to provide it for you/direct you to what specifications they follow and how to obtain those. Quote Link to comment Share on other sites More sharing options...
buildman Posted August 22, 2011 Share Posted August 22, 2011 tcec2010; Here's a site that may have a few things you can use or not. http://www.blm.gov/nstc/eng/draw.html Here's the main site link, take a look, there's a few more things here. http://www.fs.fed.us/database/acad/ Hope this helps James Quote Link to comment Share on other sites More sharing options...
