tennis4you Posted May 15, 2011 Posted May 15, 2011 When I am typing out text and get to a fraction is allows me to stack it diagonally so the 1/4" looks nicer. When i dimension, however, it does not seem to stack the fractions the same way. I took a look at the Format - Dimension setting and did not see the option in there to change it. Can someone point me to the same settings for dimensioning? I would like to have the fractions stack diagonally like they do regular text. Thanks! Quote
eldon Posted May 15, 2011 Posted May 15, 2011 If you look in the Primary Units of the Dimension style, you should be able to set the fraction format. That's where is is in my version, it should be in a similar place for you. Quote
