HVAC School project
Autocadstudent
Thanks @ReMark
I managed to finish plate1. I am now trying to understand which part of the hvac i am supposed to draft in plate 2, i dont see a duct/transition piece that is 10x14x6. . Is this the one near the nook? I am trying to understand using the images here on cad tutor about plate 2 but not able to make it out still. Is it the trasition piece that is the east split (going to bathroom 2) from the inside unit?
Edited by Rave
Thank you ! If you dont mind, could you explain where this transition is actually located on plate 1 (just to get a rough idea ,i am trying to understand which transition piece the instruction refers to, is it the one that starts from the inside unit and goes to bathroom 2?)
