I wanted a command to close and not to save.
I used the following code:
(defun c:cln () ;Close No save
   (setvar "cmdecho" 0)
   (command "close" "No")
   (setvar "cmdecho" 1)
But when I use it, it closes and saves.....help :S
This would help you with it .
(defun c:TesT ()
 (command "_.close" "_Y")
Tharwat
wouldn't that close and save? I'm not doubting you but rather inquiring why it works like that. I'm very novice in my programming.
I tried it and it works just like you said.....tho it does confuse me.
The prompts after you type "close" are "save changes to etc....." "Yes" "No" "Cancel" one would think to not save you would reply No :?
To clarify the point , just from your lisp editor type (command "_.close") and load it directly and you will be prompted with a question
  Quote
Command: 'VLIDE _.close Really want to discard all changes to drawing?
So when you type y , it means that you are certainly do not want to save , but if your answer is no , that means you do not want
to leave the drawing without saving .
Try it , it is easy .:)
Tharwat
hmmm very interesting! i have to use the visual lisp editor more, just for this sorta reason. I tend to use just notepad, but obviously that can lead to errors and mistake such as saving 15 drawings by accident....good thing i never changed anything in them :o:?
I recommend you to depend on the Visula lisp editor which is attached with Cad , that would help you a lot and much easier than
notepad without a comparison at all .
Good luck KrazyMann :)
Tharwat
  • 11 years later...
(defun c:TesT ()
Tharwat
Expand
@Tharwat Sorry to revive old thread. Just want to ask a beginner question, what is the reason putting (princ) there? As far as i know, most of routine have this but I do not know why other than returning nil for this. Thank you.
Oh i was mistaken. I thought the (princ) that return nil but the absence of (princ) that cause it. Many thanks for clearing that up for me!
I call it the "exit quietly" with out going down some technical path.
I use Tharwat code above using QQ command for "quit quietly".🤣
