iuliandonici Posted May 13, 2011 Posted May 13, 2011 Hi again, I would like to know why can't I use my layers, the ones that TURNED white while trying to import a layer state. Why aren't they "enabled" like the other layers? Quote
tzframpton Posted May 13, 2011 Posted May 13, 2011 I believe that just means they are unused. In other words, nothing is on that layer. Move something to one of those layers, and check the Status. It should be filled blue and not grayed out. Quote
BlackBox Posted May 13, 2011 Posted May 13, 2011 The layer's 'status' simply indicates if there are objects on that layer or not. :wink: To test this... try placing some objects on one of the 'white' layers (i.e., layers not in use), and then re-open the layer properties manager. Quote
