cyberrog Posted May 11, 2011 Posted May 11, 2011 Post Moved for Lisp Forum: here is the Link I'm creating a function for talude. But, on the line: command "chprop" ULT "" "LT" "" "autotalude1" "") it doesnt recognizes the command. can anyone tell me why? Here is the part of the code where I invert the propertie: (setq ULT (entlast)) (command "pedit" ult "spline" "") (setvar "celtype" "autotalude2") (initget 1 "S N") (setq inv (getkword "\nWant to Invert?<S/N>")) (if (= inv "S") (command "chprop" ULT "" "LT" "" "autotalude1" "") (setvar "celtype" "autotalude1") ;(command "pedit" ULT "r" "" "yes" "" "s" "") ;(command "pedit" ult "S" "") ) Quote
BlackBox Posted May 11, 2011 Posted May 11, 2011 I'm pretty sure this post belongs in the LISP forum. I don't have any talude lisp file (that I know of), perhaps you can post that as well? Quote
cyberrog Posted May 11, 2011 Author Posted May 11, 2011 I'm creating a function for talude. But, on the line: Code: command "chprop" ULT "" "LT" "" "autotalude1" "") it doesnt recognizes the command. can anyone tell me why? Here is the part of the code where I invert the propertie: Code: (setq ULT (entlast)) (command "pedit" ult "spline" "") (setvar "celtype" "autotalude2") (initget 1 "S N") (setq inv (getkword "\nWant to Invert?<S/N>")) (if (= inv "S") (command "chprop" ULT "" "LT" "" "autotalude1" "") (setvar "celtype" "autotalude1") ) Quote
alanjt Posted May 11, 2011 Posted May 11, 2011 If you type "S" at your getkword prompt, it should work. You could try account for language and redefining by using "_.chprop" instead. You could also try the old CHANGE command. Quote
cyberrog Posted May 11, 2011 Author Posted May 11, 2011 What do you mean "account for language"? Quote
alanjt Posted May 11, 2011 Posted May 11, 2011 cyberrog said: What do you mean "account for language"? In case you aren't using an English version of AutoCAD. Quote
SLW210 Posted May 11, 2011 Posted May 11, 2011 I have combined your posts, there is no need to create two threads for same question. If you feel you have posted in wrong section, a moderator can move your thread for you. Multiple threads for the same question gets confusing. Thank you. Quote
