mnewton Posted May 10, 2011 Posted May 10, 2011 Is their a protocol for making a block with visibility states? I have not done this in a long time but I know the procedure for creating the visibility states but for some reason no matter how many times i adjust this one block i cannot get the this attribute definition to stop showing in visibility states. i have tried doing a showall and hiding this attribute manually over and over again and i cannot get the block to hold the info. it looks right in the block editor but as soon as i insert this block i can see the visibility state is not right. is their a procedure of how i set up a block like this so that the visibility states will work the way i want them too? Quote
dbroada Posted May 10, 2011 Posted May 10, 2011 I think the block edit was changed for 2010 but with the earlier versions I never had consistent results with attributes and visibility states. I now always try to find a different way of doing it rather than get frustrated with it. Quote
mnewton Posted May 10, 2011 Author Posted May 10, 2011 Ummm Well thank you but that was not really any help. I have tried a number of different methods of hiding and showing the objects with the same results. for some reason it only screws up with attributes and i dont know why. their has to be a way to make it work right. like selection or something to make a attributed block with visibility states work. i have done it in the past a few years ago. someone please help Quote
qball Posted May 11, 2011 Posted May 11, 2011 my opinion is it's a glich in Autocad. I have the same problem sometimes. But the good news is, by me writing this I'm subscribed to the thread so if someone does have a solution, I'll be notified too! Quote
