Hi,
I am trying to create a 3D elbow that is Ellipsed at one end and is circlular at the other. Im not sure how to go about making this and would be much apprecated for any help to do it !
I've attached and example of what im trying to make.
Thanks
Andy!
Elliptical or oblong?
Use the Loft command with the Path option. It should work.
I would loft between a couple of extrusion using centerline guide curve, union and shell.
Down and dirty example. Linework at upper left end and finished elbow at lower right. Probably could have eliminated a couple of steps had I used the Region command.
Using Region/Subtract first.
hi guys!
Thanks for helping me with this! sorry for taking so long to reply im just back at work.
the loft tool worked great!
thanks again!
Andy
