woodman78 Posted May 9, 2011 Posted May 9, 2011 I am creating a lisp for road hatching. This is what I have so far. It works by selecting a base line and inserting a blocka long it using the measure command. Create a selection set of the blocks and explode them. Then select an outline and that is offset inside (the user selects the side to offset to. Can this default to inside?) I need then to create a selection set of the exploded lines and to trim them from the offseted outline. I am struggling with the last few bits and would appreciate some help. Quote
woodman78 Posted May 9, 2011 Author Posted May 9, 2011 sorry forgot to include my code. i will in work in the morning. Quote
BIGAL Posted May 10, 2011 Posted May 10, 2011 First Dont use blocks for thick lines use plines extra work to trim a block. Have a look at the command "extrim". It will trim inside or outside the chevrons normally dont touch the inside line so offset the inner for the trim line use "last" then erase "last" should remove it. Just did manual draw island draw plines and copy etc offset island to inside EXTRIM L point out side all done E L finished. The main thing is pick start and end for pline orientation and make long enough to cover most islands. It took seconds to do from scratch. Post code interested helping you I would use it. Quote
woodman78 Posted May 10, 2011 Author Posted May 10, 2011 This is the code I have so far. (defun C:hatch_lining (/ ang coords elist midp offsetted offsetted1 ofpt p1 p2 p3 pline side SUCE SUOM SUSM SUAB SUAD SUCL SUCR) (setq SUCE (getvar "cmdecho")) (setq SUOM (getvar "orthomode")) (setq SUSM (getvar "osmode")) (setq SUAB (getvar "angbase")) (setq SUAD (getvar "angdir")) (setq SUCL (getvar "clayer")) (setq SUCR (getvar "cecolor")) (setq vl1 (list (cons 0 "LAYER") ;Name of entity (cons 100 "AcDbSymbolTableRecord") ;Open Records (cons 100 "AcDbLayerTableRecord") ;Locate Layer Table (cons 2 "CCC_LAYOUT_Proposed_Road_Lining_Hatching") ;Name of Layer (cons 6 "Continuous") ;Linetype (cons 62 7) ;colour = light grey (cons 70 0) ;state (cons 290 1) ;1=plot, 0=Don't plot ) ;End of entity list ) (entmake vl1) (command "_.-layer" "_C" "3" "CCC_LAYOUT_Proposed_Road_Lining_Hatching" "") (setvar "clayer" "CCC_LAYOUT_Proposed_Road_Lining_Hatching") (setvar "cecolor" "1") (setq pline(entsel "\nSelect an arc or a polyline: ")) (setq coords (vl-remove-if (function not) (mapcar (function (lambda (x) (if (= 10 (car x))(cdr x)))) elist)) ) (setq p2 (car coords) midp (mapcar (function (lambda( a b)(/ (+ a b) 2))) p1 p2) ) (command "measure" pline "b" "hatch Lining" "y" "2" "") (command "_change" pline "" "p" "Layer" "CCC_LAYOUT_Proposed_Road_Lining_Hatching" "color" "Bylayer" "") (setvar "qaflags" 1) (setq SS1 (ssget "X" (list '(0 . "INSERT") (cons 2 "hatch Lining")))) (command "explode" SS1 "") (setvar "qaflags" 0) (setq sel1 (ssget "x" '((8 . "CCC_LAYOUT_Proposed_Road_Lining_Hatching_Construction")))) (setq outpline(entsel "\nSelect a closed polyline: ")) (setq inside(getpoint "\nPick an offset side: ")) (command "._offset" 0.3 outpline inside "") (setq offsetted (entlast) elist (entget offsetted) ) (setvar "cmdecho" SUCE) (setvar "orthomode" SUOM) (setvar "osmode" SUSM) (setvar "angbase" SUAB) (setvar "angdir" SUAD) (setvar "clayer" SUCL) (setvar "cecolor" SUCR) (princ) ) Quote
woodman78 Posted May 10, 2011 Author Posted May 10, 2011 I have tried calling "extrim" using Command in the lisp but it doesn't work. How do I call it? And can I use a selection set of items to trim? Quote
woodman78 Posted May 10, 2011 Author Posted May 10, 2011 I have worked manually with "cookiecutter2" from Joe Burke and it works great. How can I call it from my routine? Example (command "cookiecutter2") Quote
woodman78 Posted May 10, 2011 Author Posted May 10, 2011 I got it sorted. I added to my file and called it then. I commented out the parts of cookiecutter2 I didn't need. It works fine. Quote
woodman78 Posted May 10, 2011 Author Posted May 10, 2011 Here is the finished cde. I know it's not elegant and is very clunky but it does what I need it to do I can't attach the blocks that create the lining but they are very simple. They are just plines passing through the origin at 45 degrees in both directions and about 6m either side of the origin. Hatch_Lining.lspFetching info... Quote
BIGAL Posted May 11, 2011 Posted May 11, 2011 The better way to do it is to create parallel lines = width of chevrons use extrim to offset inside of island then use hatch solid and it gives a perfect shape then to the arc sides. And yes like you I could not get Extrim to work in plain lisp (command "extrim" "last" pt1) gives unknown command, any one have an idea ? Yhen I can make the hatching automatic quite easy. Just get start pt of line end point of next line pick pt for hatch is half start-end. Quote
woodman78 Posted May 11, 2011 Author Posted May 11, 2011 Bigal, Parallel lines works fine if the hatching is along a straight but most of ours wouldn't be. I had trouble with the extrim and I saw somewhere on the web about loading it first within the lisp as a different name and calling the name as you need it. I couldn't find it again though. Even when I ran extrim manually though I had problems. I found cookiecutter2 to be much better. I commented out the parts that I didn't want and it works great. Quote
BIGAL Posted May 12, 2011 Posted May 12, 2011 (edited) You are right if you have an arc of a tight radius the chevron should be at a correct angle to the point on the arc so the paired lines would rotate as they are copied along, it has to be paired lines as the road paint guys have cutouts of the painted width. It could be done but a lot more complicated in the automation. you could use circular array to achieve the result but a lot more maths involved. Will think about it more and search for extrim answer. Found an answer over at THESWAMP thanks to AlanJT do the following (load "extrim") ; its part of the express lisps (setq pt1 (getpoint)) ; outside pick point (setq objent (car (entsel))) ; pick trim pline (etrim objent pt1) should all be done add some prompts etc Edited May 12, 2011 by BIGAL found Quote
woodman78 Posted June 1, 2011 Author Posted June 1, 2011 Thanks Bigal but can I restrict extrim to only trim objects on a certain layer? I want to be able to trim a selection set of polylines by selecting a trim line and a point outside the line. This can be in a heavily populated drawing and I fear extrim is a bit like using a chainsaw when a chisel will do!!!! It could cause untold damage by trimming other objects. Quote
woodman78 Posted June 8, 2011 Author Posted June 8, 2011 Can Bigal's piece of code above be modified to trim the lines around the pline chosen and not just on one side? Quote
BIGAL Posted June 8, 2011 Posted June 8, 2011 You would need to use say layiso first then add chevrons automatically then extrim. then turn all layers back on. Quote
woodman78 Posted June 9, 2011 Author Posted June 9, 2011 Does anyone have a routine that will isolate a layer based on layername and not on selecting a layer on screen? Thanks. Quote
Lee Mac Posted June 9, 2011 Posted June 9, 2011 woodman78 said: Does anyone have a routine that will isolate a layer based on layername and not on selecting a layer on screen? I'm sure you could put one together using the LAYER command: (command "_.-layer" "_OFF" "*" "_Y" "_ON" pause "") Quote
woodman78 Posted June 9, 2011 Author Posted June 9, 2011 What does the pause do in that LeeMac? Quote
krzyche Posted August 5, 2014 Posted August 5, 2014 Hi woodman78. I know it's been 3 years since your previous post. But I have question - did you finish lisp which draws the road cross hatch or chevron hatch? Can you tell me what is easiest way to draw this kind of marking in Civil 3D? Quote
