resullins Posted May 6, 2011 Share Posted May 6, 2011 Why can't I do this? It doesn't seem that hard? See screen shot below... Quote Link to comment Share on other sites More sharing options...
jaylo23 Posted May 6, 2011 Share Posted May 6, 2011 That is because your text style "TEXT-" has a height set to 0.1250. If you use the command "style" and select "TEXT-1" and set its height to 0 instead of 0.150 you will then be able to change the height in the attributes editor. Or just create a new text style in the style command, set its height to 0 and have your attribute use that text style. 1 Quote Link to comment Share on other sites More sharing options...
SLW210 Posted May 6, 2011 Share Posted May 6, 2011 Change the justification then change it back. You can also change the text styles back and forth and the text height becomes editable. Quote Link to comment Share on other sites More sharing options...
resullins Posted May 6, 2011 Author Share Posted May 6, 2011 Hm... I've never thought about that before. Thanks guys! Quote Link to comment Share on other sites More sharing options...
irneb Posted May 9, 2011 Share Posted May 9, 2011 Another thing to try is hold down Ctrl when selecting the attribute (if it's a hidden attrib, then look at AttDisp). Then you can modify those properties through the Properties Palette (Ctrl+1), not to mention you can modify more than one Attrib's properties at once. Quote Link to comment Share on other sites More sharing options...
MC5fan1968 Posted November 22, 2021 Share Posted November 22, 2021 I am using ACADE 2020 and this is not working. Any further suggestions? Quote Link to comment Share on other sites More sharing options...
