Hi,
as most of you know, the syntax of mapcad function is as following:
(mapcar [i]function [/i][i]list1[/i]... [i]listn[/i])
My question can be explained after showing these two examples:
(mapcar 'strcase '("a" "B" "c" "D"))
returns: ("A" "B" "C" "D")
(mapcar 'strcase '("a" "B" "c" "D") '(T T T T))
returns: ("a" "b" "c" "d")
Is any method to pass repeated objects (here T as the socond argument) to mapcar just one time?
*IF* you know you'll be using T (True) as the Which argument of the Strcase function for each item of the supplied list of valid strings, then the use of Lambda should do the trick.
Example:
(mapcar
 [color=blue](function[/color]
[color=blue]   (lambda (str / string)[/color]
[color=blue]     (setq string (strcase str [color=red]T[/color]))))[/color]
 '("a" "B" "c" "D"))
Nice one RenderMan - much appreciated:).
(mapcar
[color=blue](lambda (str / string)[/color]
[color=blue](setq string (strcase str [color=red]T[/color]))))[/color]
'("a" "B" "c" "D"))
the code can be even shorter:
(mapcar
 (function
  (lambda (str)
   (strcase str T)))
 '("a" "B" "c" "D"))
Thanks again RenderMan
Mapcar is ideal when processing lists of unknown length; should you need to supply other constant arguments for each item, a lambda function (or user-defined subfunction) may be used, as demonstrated.
Perhaps have a read of this tutorial, the link at the bottom of that page is also a good read.
Your welcome. :)
Thanks Lee,
you are very good teacher.
