Miniver Posted May 4, 2011 Author Posted May 4, 2011 Hi. Prob some at 1:10 and some at 1:20 that should do it Quote
ReMark Posted May 4, 2011 Posted May 4, 2011 What annotative scales were you planning to use for your text? As far as I can tell there are none assigned in the stripped.dwg you posted above. What size paper were you eventually going to use? Quote
Miniver Posted May 4, 2011 Author Posted May 4, 2011 I was going to use A1 and thought about 3mm text if that sounds right? Quote
ReMark Posted May 4, 2011 Posted May 4, 2011 Will you be showing the same objects in different viewports with different scales? Quote
Miniver Posted May 4, 2011 Author Posted May 4, 2011 No. Some objects will be 1:10 and others will be 1:20 Quote
ReMark Posted May 4, 2011 Posted May 4, 2011 You may well find that doing both your dimensioning and text in your paper space layout will be easier, at this point in time, than working with annotative scaling in model space. One drawback is that if an object must appear in two different viewports, at two different scales, you would have to dimension the object twice. Using annotative scaling you would dimension the object only one, back in model space, and assign the different annotative scales to all the dimensions. When you switch to your layout and look at each viewport (even though they could be assigned two different scales) the text would display properly in both and when plotted all the text would be the same size. Quote
Miniver Posted May 4, 2011 Author Posted May 4, 2011 Ok. Thanks for that. I've sort of started in modelspace tho. And cant really figure out how to do either properly Quote
ReMark Posted May 4, 2011 Posted May 4, 2011 Miniver said: Ok.Thanks for that. I've sort of started in modelspace tho. And cant really figure out how to do either properly Maybe this will help. Dim Text in Layout.dwgFetching info... There are a couple of typos in the drawing. I'm in a rush to get something finished before I leave work. My apologies. When it comes time to plot do so at a scale of 1:1 (1 mm = 1 unit). AutoCAD will handle the viewport scaling and each will plot according to the assigned scale. Quote
Miniver Posted May 4, 2011 Author Posted May 4, 2011 Thanks for your help. I'm just going to open it. Quote
ReMark Posted May 4, 2011 Posted May 4, 2011 Miniver said: Thanks for your help.I'm just going to open it. It's the best I can do for the moment. I must be on the road shortly. If you have further questions I'm sure one or more of the much smarter forum members here will assist you. Do not give up hope. I believe you can do it with a little guidance from us. Quote
Miniver Posted May 4, 2011 Author Posted May 4, 2011 Hi, Thats great thansk. Just what I needed to do but couldn't. One small issue- Ive pasted some of my preious drawing into model space, slid them about in the viewports and now, when i dimension them on the red layer in paperspace the text is really tiny again. I didn't change any settings I think. Is there a way I can change the text size of measuremnst in paperspace? Quote
Miniver Posted May 4, 2011 Author Posted May 4, 2011 should i be writing in the viewport with them locked or unlocked? Quote
Miniver Posted May 4, 2011 Author Posted May 4, 2011 BEAKTHROUGH! I am now dimesnioning and labelling just like a person with a pen! Thanks guys. Quote
designerstuart Posted May 5, 2011 Posted May 5, 2011 haha 46 posts later..... that's gotta be a new record! glad we could help. (remark - your patience is some sort of titanium alloy) Quote
ReMark Posted May 5, 2011 Posted May 5, 2011 Miniver said: BEAKTHROUGH! I am now dimesnioning and labelling just like a person with a pen! Thanks guys. Did you finally complete the task? I'm assuming you realized that clicking inside a viewport meant you were actually working in model space and not paper space. Did you figure out how to unlock the display? Did you figure out how to adjust the size of your viewport? Finally, did you successfully print your drawing? Quote
ReMark Posted May 5, 2011 Posted May 5, 2011 designerstuart said: haha 46 posts later..... that's gotta be a new record! glad we could help.(remark - your patience is some sort of titanium alloy) I was only trying to make amends for the harsh treatment I subjected someone to in a previous thread. I would refer to myself as generally impatient. Quote
DANIEL Posted May 5, 2011 Posted May 5, 2011 polymometic alloy ... oh wait, wrong terminator ... Quote
