Epicurwin Posted May 3, 2011 Posted May 3, 2011 I'm tring to plot 26 or so sheets into a single pdf or multiple pdfs and I get this error every time with no file being created. [/url]Job: - Canceled Job ID: 1 Sheet set name: Date and time started: 5/3/2011 11:48:29 AM Date and time completed: 5/3/2011 11:48:33 AM UserID: RGDC99 Profile ID: AutoCAD MEP (US Imperial) Total sheets: 2 Sheets plotted: 1 Number of errors: 1 Number of warnings: 0 Sheet: P-AIR-# FAB-AIR-1 - Plotted with Error(s) File: Z:\_xxxxx\_xxxxx\2011 Projects\xxxxx\CAD\P-AIR-# FAB.dwg Category name: Page setup: pdf Device name: DWG To PDF.pc3 - plotted to file Plot file path: Z:\_xxxxxx\_xxxxxx\2011 Projects\xxxxxx\PDF's\OUTBOUND\xxx\P-AIR-# FAB.pdf Paper size: ANSI full bleed A (11.00 x 8.50 Inches) ERROR: Internal Error: Null Pointer Sheet: P-AIR-# FAB-AIR-1 - Error(s) Did Not Plot File: Z:\_xxxxx\_xxxx\2011 Projects\xxxxxxx\CAD\P-AIR-# FAB.dwg Category name: Page setup: pdf Device name: DWG To PDF.pc3 - plotted to file Plot file path: Z:\_xxxxxx\_xxxxx\2011 Projects\xxxxxx\PDF's\OUTBOUND\xxxx\P-AIR-# FAB.pdf Paper size: ANSI full bleed A (11.00 x 8.50 Inches) What is the problem? Quote
tzframpton Posted May 3, 2011 Posted May 3, 2011 Do you have access to the mapped drive or is it disconnected? Try publishing to the Desktop and see if it works then. Quote
Epicurwin Posted May 3, 2011 Author Posted May 3, 2011 Do you have access to the mapped drive or is it disconnected? Try publishing to the Desktop and see if it works then. I'm sure that the drive is connected, but I still tried publishing it to the desktop and I also copied the cad file to the desktop and publishing to the desktop. Same error, same issue. Quote
BIGAL Posted May 4, 2011 Posted May 4, 2011 Can you do a normal plot to pdf rather than publish. Maybe also download cutepdf its free, maybe something wrong with dwg to pdf ? Quote
tzframpton Posted May 4, 2011 Posted May 4, 2011 The only downfall regarding CutePDF is that it doesn't handle patch plotting/publishing well, if at all. Quote
