Hi all
I am having a problem with the TORIENT command which aligns text and other stuff to a particular angle for example a line
Now i am very lazy and have millions of text to align with different line i wanted to make a shortcut to this command an i created this lisp
[font=Tahoma](defun c:to () (command "torient"))[/font]
But I doesn't work for me it says that it is an unknown command.
But when I type it in manually it works fine
If this helps there is a variable torient i looked that up using
!torient
You don't need a lisp routine for this. Just put a command alias in your pgp file.
Just for completeness:
Since TOrient is an Express Tool command, it cannot be called using the command function in LISP, instead you can call it using:
(defun c:to nil (c:torient))
*cough*AGREE*cough*
This works well thanks it is just a simple lisp now but i have a lisp that im working on that could use this command as well
Thanks Lee Mac
Where do you find the pgp file and is it like a short cut registry or something
The pgp file contains all of your command aliases. You can access it from within Autocad by going to the Tools menu > Customize > Edit Program Parameters (acad.pgp). The file will open in Notepad and you can edit existing aliases or add your own at the bottom, in the "User Defined" section.
Here's another way to create command aliases through the Express Tools Alias Editor: http://www.ellenfinkelstein.com/AutoCAD_tips_create_alias.html
Whatever way you choose to edit your pgp file, you will need to run the REINIT command after editing in order for your changes to take effect.
Note: Whenever making changes to any files, be sure to save an unedited backup copy, in case you royally screw it up. :wink:
If you use the Express Tools "Command Alias Editor" you don't need to run ReInit afterwards. :wink:
Thanks everyone
  • 3 weeks later...
Hi again this it being a while since i fixed this problem but i am have the same problem again but a little different this time.
I am trying to create a shortcut to a lisp. Now if i had the ablity to edit this lisp i would just change the (defun c:ncopy ()..... to (defun c:nc ()....... but i don't have access to it or at least i don't think i do.
So is there a way to shortcut the a lisp
(defun c: nc ()
(command ncopy))
This does not work so what am i doing wrong
Slight modification...
(defun c:nc ()
 (c:ncopy)
Forget LISP macros, just edit your acad.PGP
agreed.
Sometimes folks may want a temporary override for a command alias. It is still not good practice to modify native AutoCAD command aliases. Check the ACAD.pgp and add aliases that are not currently in use, otherwise, it drives your CADD Department Manager up a wall when trying to troubleshoot what went haywire on your machine. :wink:
Also, the CADD Manager usually has a few tricks up his/her sleeve that can truly tweak your machine back into submission! :twisted:
I might even resemble that remark.
Thanks man i knew i was close
