cyter Posted May 1, 2011 Posted May 1, 2011 My drawings appear small in paper space than they do in model space. How do i get them to fill the paper space? Quote
mateen Posted May 1, 2011 Posted May 1, 2011 Tell me your drawing is on scale or nts (not to scale)... Quote
mateen Posted May 1, 2011 Posted May 1, 2011 if your drawing is on scale so you have to change scale then you fill paper space. otherwise on paper space you have to apply z space then e space... then u look it will be fill Quote
ReMark Posted May 1, 2011 Posted May 1, 2011 In paper space you should be utilizing a viewport to see what you created back in model space. Viewports can be resized using their grips. What scale have you assigned to your viewport? Quote
JD Mather Posted May 1, 2011 Posted May 1, 2011 Zip and attach the file here. We spend all of this time learning to communicate with geometry - let's communicate with geometry. Quote
Cad64 Posted May 1, 2011 Posted May 1, 2011 You might want to take a look here: http://www.we-r-here.com/cad/tutorials/level_2/2-8.htm cyter said: My drawings appear small in paper space than they do in model space. How do i get them to fill the paper space? Quote
cyter Posted May 2, 2011 Author Posted May 2, 2011 I'd also like to know how to dimension 3d objects. http://www.zip-online.net/uploads/110501072352-34756.zip Quote
cyter Posted May 2, 2011 Author Posted May 2, 2011 Here's another file; http://www.zip-online.net/uploads/110501072622-51590.zip Quote
cyter Posted May 2, 2011 Author Posted May 2, 2011 I'm only remaining with the lower jaw to be done with my project. Here's another file; http://www.zip-online.net/uploads/110501072622-51590.zip Quote
Cad64 Posted May 2, 2011 Posted May 2, 2011 One question at a time please. Have you solved the initial problem you posted about at the beginning of this thread? Do you understand how to use viewports and set the scale so that your drawing fits the viewport? And please don't lump all of your questions into this one thread. If you have other questions that are unrelated to the topic of this thread, please start a new thread. Quote
