Had a look in the search can't find a straight forward answer.
Is it possible to change the insertion point of a block once its already been created?
few methods I know & use.
If I want to do it here in the drawing itself, i open the block in bloock editor & select all the objects & move the point i want as insertion point to 0,0,0.
another method if the block is in seprate file. go to that file & change the 'insbase'> than 'redefine the block' in your drawing using 'design center'
Thats the Baby thanks :D
you can also do a bedit (2k6 + full version) on the block and add a basepoint parameter...
  • 4 weeks later...
I was wondering the same, thank you this was very helpful.
