Ahankhah Posted April 26, 2011 Share Posted April 26, 2011 Hi CADTutormates, is it possible to know the name and location of current code by itself? If yes, how? For example, if the loaded program is: "c:/MyFolder/Myprogram.fas", needed to find strings: "c:/MyFolder/" and "Myprogram.fas"? Quote Link to comment Share on other sites More sharing options...
pBe Posted April 26, 2011 Share Posted April 26, 2011 You can pass the filename arguments using this http://www.cadtutor.net/forum/showthread.php?58069-How-to-find-a-drawing-in-my-Coumputer-drives Quote Link to comment Share on other sites More sharing options...
Ahankhah Posted April 26, 2011 Author Share Posted April 26, 2011 You can pass the filename arguments using this http://www.cadtutor.net/forum/showthread.php?58069-How-to-find-a-drawing-in-my-Coumputer-drives A good thread to study pBe, but I didn't find any solution to my problem:P. Quote Link to comment Share on other sites More sharing options...
LibertyOne Posted April 26, 2011 Share Posted April 26, 2011 If you run the command "_APPLOAD" the dialog shows a list of all loaded *.lsp, *.arx, *.fas, etc. files. Getting that information in the form that you need my be a bit difficult. Quote Link to comment Share on other sites More sharing options...
MSasu Posted April 26, 2011 Share Posted April 26, 2011 The list of currently loaded AutoLISP files can be retrieved using the dos_lisplist function from DOSLib pack. Also the CMDACTIVE system variable will tell you the active action (however if an AutoLISP routine is the active one this is visible only from an ARX tool). Not sure if those may help you. Regards, Mircea Quote Link to comment Share on other sites More sharing options...
Ahankhah Posted April 26, 2011 Author Share Posted April 26, 2011 If you run the command "_APPLOAD" the dialog shows a list of all loaded *.lsp, *.arx, *.fas, etc. files. Getting that information in the form that you need my be a bit difficult. LibertyOne, Maybe the way "_.APPLOAD" gets and keeps in mind the name and path of applications (programs) is good to achieve the goal:), but how to do that by coding in AutoLISP:huh:? Quote Link to comment Share on other sites More sharing options...
Ahankhah Posted April 26, 2011 Author Share Posted April 26, 2011 The list of currently loaded AutoLISP files can be retrieved using the dos_lisplist function from DOSLib pack. Mircea, when I want to find "DOSLib18.arx" in the directory of my code, the paradox happens. First step is finding the program like one mentioned to load it via my code. How this step should be done:unsure:? Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted April 26, 2011 Share Posted April 26, 2011 findfile? .. Quote Link to comment Share on other sites More sharing options...
Ahankhah Posted April 26, 2011 Author Share Posted April 26, 2011 findfile? .. Of course Lee, when the file is in the sme folder of current code, but the folder isn't in the search path of (findfile). Quote Link to comment Share on other sites More sharing options...
alanjt Posted April 26, 2011 Share Posted April 26, 2011 Maybe you need to start organizing things a little better. Quote Link to comment Share on other sites More sharing options...
BlackBox Posted April 26, 2011 Share Posted April 26, 2011 Of course Lee,when the file is in the sme folder of current code, but the folder isn't in the search path of (findfile). Ahankhah, consider how much less typing you'd do, if you no longer needed (most?) hard-coded file paths in your code, which would also make your code easier to maintain if / when paths change... PLUS the added benefit of using findfile... sounds like a win-win-win to me. Quote Link to comment Share on other sites More sharing options...
alanjt Posted April 26, 2011 Share Posted April 26, 2011 Ahankhah, consider how much less typing you'd do, if you no longer needed (most?) hard-coded file paths in your code, which would also make your code easier to maintain if / when paths change... PLUS the added benefit of using findfile... sounds like a win-win-win to me. Agreed. (load "file" nil) is a lot less work than (load "c:\\folder\\folder\\folder\\folder\\folder\\folder\\folder\\file" nil) Quote Link to comment Share on other sites More sharing options...
Ahankhah Posted April 26, 2011 Author Share Posted April 26, 2011 It shows I am not so clear, perhaps for my bad explanation. Assume that you have a code (I name it "main program"). The "main program" needs to load another program ("reference program"). Both "main program" and "reference program" are located in the same folder, regardless of folder's name and location. The problem is I want to find "reference program" while (findfile) can't find it as well refering it without clarifying the path does nothing. I hope this time I am clear enough. Quote Link to comment Share on other sites More sharing options...
LibertyOne Posted April 26, 2011 Share Posted April 26, 2011 Hi CADTutormates,is it possible to know the name and location of current code by itself? If yes, how? For example, if the loaded program is: "c:/MyFolder/Myprogram.fas", needed to find strings: "c:/MyFolder/" and "Myprogram.fas"? I'm curious, what would be the advantage of knowing this? I mean, knowing what apps are loaded is one thing. But asking the location from where the app is loaded may not be relevant. It's like waving down a taxicab and after getting in, asking the driver from where he just arrived. Quote Link to comment Share on other sites More sharing options...
LibertyOne Posted April 26, 2011 Share Posted April 26, 2011 It shows I am not so clear, perhaps for my bad explanation.Assume that you have a code (I name it "main program"). The "main program" needs to load another program ("reference program"). Both "main program" and "reference program" are located in the same folder, regardless of folder's name and location. The problem is I want to find "reference program" while (findfile) can't find it as well refering it without clarifying the path does nothing. I hope this time I am clear enough. ok, I would go about doing this a completely different way. I would first check if the "reference_program" was loaded or not. (atoms-family 1 "reference_program") If it's not loaded then I would load it knowing where the reference program is saved. Quote Link to comment Share on other sites More sharing options...
Ahankhah Posted April 26, 2011 Author Share Posted April 26, 2011 ok, I would go about doing this a completely different way. I would first check if the "reference_program" was loaded or not. (atoms-family 1 "reference_program") If it's not loaded then I would load it knowing where the reference program is saved. In this code: (atoms-family 1 '("reference-program")) "reference-program" refers to a function/command/variable and not a file. Quote Link to comment Share on other sites More sharing options...
BlackBox Posted April 26, 2011 Share Posted April 26, 2011 In this code: (atoms-family 1 '("reference-program")) "reference-program" refers to a function/command/variable and not a file. If you want to (I'll use a different word) *identify* the name of a sub-function called from a primary function, then in a new / blank file in VLIDE: (defun c:FOO () [color=red][b]([/b][/color]<PrimaryFunction>)) [color=red]; <- Red paren represents breakpoint[/color] (c:FOO) ... and load the above code. When the VLIDE breaks at the leading paren notated above, simply step through the code using F8, one line at a time. This *should* open the resultant / dependent routines (assuming they're .LSP?), and subsequent steps (pressing F8 ) *should* allow you to step through the newly opened / dependent sub-functions being called. I'm still completely perplexed why you are pursuing this, given that you already know that the sub-function ("reference program") resides within the same directory. Furthermore, unless the "main program" is hard-coded to load the "reference program", the latter is being loaded by another routine, perhaps by ACADDOC.lsp? I see you're using 2012; perhaps this is the result of your using the *autoload* folder? Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted April 26, 2011 Share Posted April 26, 2011 When a file is loaded into memory, you only have access to the defined symbols in the document namespace, not the file from which they were loaded. Quote Link to comment Share on other sites More sharing options...
alanjt Posted April 26, 2011 Share Posted April 26, 2011 When a file is loaded into memory, you only have access to the defined symbols in the document namespace, not the file from which they were loaded. Precisely. Hell, you can copy a LISP routine and paste it directly into the command line. Quote Link to comment Share on other sites More sharing options...
BlackBox Posted April 26, 2011 Share Posted April 26, 2011 Quote Link to comment Share on other sites More sharing options...
