doru10 Posted April 25, 2011 Posted April 25, 2011 Hello all, I want to put a text about the polyline. Now I do the steps listed below. 1. polyline with Len2Fld.lsp read. 2. edit text for the street, material and diameter. 3. text-align with DTCurveV2 9.lsp. (Thank you very much Mr. Lee McDonnell.) It is a procedure if a large enough clusters with 50,000 inhabitants. The above-mentioned wish to edit in a single pass. -polyline-read length, choose the material and diameter (from a list) and finally to have an open field where you enter the street name or other (can be 2 to 3 fields to fill). Attach to a water network example I apologize for my English. I'm use Acad2008. Best Regards. Sample Water Network 3.dwgFetching info... Quote
doru10 Posted May 2, 2011 Author Posted May 2, 2011 Hello all, there is no solution to the problem mentioned above? Best Regards. Quote
