SanMiguel Posted April 25, 2011 Posted April 25, 2011 im having problems with using fillets....everytime i use fillet with my polylines...it gives me reverse fillets instead of inside fillets(dont know how to call it)......how do i change this??? Quote
ReMark Posted April 25, 2011 Posted April 25, 2011 Perhaps it is a result of where you are making your "picks". Quote
SanMiguel Posted April 25, 2011 Author Posted April 25, 2011 tried changing picks....tried adjusting ucs ....only thing that works is that changing the radius but dont want to do that.....any other suggestions??? thanks Quote
eldon Posted April 25, 2011 Posted April 25, 2011 Usually when you fillet a polyline, you just pick the polyline, and it fillets all the corners. Perhaps you could post a drawing with just that polyline in it and nothing else Quote
Organic Posted April 26, 2011 Posted April 26, 2011 I have had this occur before although cannot recall how. Quote
SanMiguel Posted April 26, 2011 Author Posted April 26, 2011 quick bang your head up a wall or something....maybe your amnesia will go away....lol.....just kiddin man..... let me know if you remember in your dreams.....thanks.... Quote
SLW210 Posted April 26, 2011 Posted April 26, 2011 If you could post the file it may help. Try running _OVERKILL command and see if there are some extra lines in there. If you change the radius enough to get it the correct fillet, can you then fillet at the correct radius? Quote
