Hello everyone,
does anyone knows a way to define a function in AutoLISP with arbitrary arguments, same as ARX?
Do you mean 'optional' arguments?
For LISP, the answer is no, the number of arguments in the function definition must be supplied when calling the function - such arguments may be nil however:
(defun example ( arg1 arg2 arg3 )
 (print arg1)
 (print arg2)
 (print arg3)
(example "ABC" 123 nil)
Thank you Lee for correcting my writing. I learn from you more than programming:D.
You can pass an unknown number of arguments in a list then have the function parse the list;
(defun example (aug1)
(foreach item aug1
(print item)
);_foreach
);_defun
;;;Calling the function
(example ‘( “Hello” “Aloha” “Hola” “Ciao” “Guten Tag[color=black][font=Arial]”[/font][/color]))
JohnM,
what you posted is fine to conquer the limitation of AutoLISP. Thank you very much.
