Hello, is it possible to include text along unrolled polysrf and points? The texts are baked from grasshopper tagging the points on the surfaces. I've tried to explode them into curves, but they are still not appearing on my unrolled surface. I've attached the rhino file here. Thank you!
octagons1.zip
I think it possible via Rhinoscript or other programmingmethods, though I’m not sure about grasshopper. I haven’t had the time to investigate GHfunctionality.
It looks like you are tagging these faces for fabrication. If that is true would using the “Labels=Yes”option of the UnRollSrf command – with, perhaps, a more specific layering scheme – accomplish the same thing?
