Dear Sir,
I have installed autocad-2007 since one year. There is no problem in working with the version. but from 2 days i am facing a problem that is shown in a enclosed attachment. I had uninstalled autocad-2007 and again installed the same but the same error is showing. Now i had tried 2008 it also shows the same. Please clarify to use rectify the same.
Srinivas
Install .NET Framework 3.5 Service Pack 1. That should solve problem. Directions can be found online at the AutoDeskl and Microsoft websites.
  • 4 weeks later...
For 2007 NF 3.5 SP1? I think the NF is using for autocad is 1.1 or 2.0. Install this versions with all service packs.
I get this some times with specific files and am able to correct it with a recover on the file itself.
But this error in special is with the net framework, because I am technical support for autocad 2006 until 2011 in my work.
Regards...
